Does nobody apply a bit of copper-slip to bolts/studs these days.... and to the faces of alloys/hubs? I know there is a risk of them loosening, but its never been an issue to me me with hand tightened bolts.
Went out in the Mevster on Friday still had the misfire issue until about 10 miles from home where it died completely whilst waiting for the recovery truck I found a wire which may have been rubbing on an engine lifting point
The fault was a blown main ECU fuse easy repair once I could get to it, but it still left me with a P1504 OBD error, which is supposed to be the IACV which the Orange wire from above fed, so I thought it could possibly be faulty & replaced it with known good one but the error still remains, another side effect was on the MX5 they have an anti-stall feature where if you put the clutch down & put it in gear the engine revs increase, this stopped working so I figured the ECU might be fried. Got another ECU, immobiliser & key set, fitted that tonight, I now don't get the P1504 error or the clutch/gear issue, but get P1562 & P1499 errors.
I'm now really confused how I can get different errors depending on which ECU I fit.
They only ever made 20, 8 of them on the road, a 9th is currently for sale but needs IVAing if it's still for sale after I sell my Exocet I may consider it, not sure where the other 11 areI do like the Mevster - much more civilised than the 'open to the elements' MEV designs. The Mevsters don't seem to have been as popular though?
That's a good achievement, was the oil pump chain okay?Sons mini cooper S noisy chain fixed with new tensioner!
Proud he managed it!!
(With a little help from dad!)
Debatable whether they were ever really BMW engines at all, seeing as they were derived from the Peugeot TU block.
My breakdown saga continues, first ECU shows one error, second ECU shows a different error, first ECU also exhibits an issue that the anti-stall feature isn't working, second ECU doesn't show that fault, so pretty sure something in the first ECU is fried it took too much voltage/amperage down a circuit & killed something.
Started to investigate the issues on the second ECU & found a post about pin corrosion, for whatever reason Mazda put the ECU in the passenger footwell under the carpet, under a security plate but as low down as they could & had all the wiring at the bottom, all this in an open topped car. Pin 4AG has a 12V permanent live going to it, checked the wiring at the end of the harness & I have 12V so I opened up the ECU to find.
Touched the Pin & this happened
For now I have soldered a wire on to bypass the connector, but it appears I have the same issue on pin 4AE which is close, so that is tonights job
Only 35 miles away so I ought to go & support it, although it's not my favourite place, but sure I'll be there on 1 of the days (hopefully)Crikey - that look a difficult and delicate job. See you at Newark?
Sounds like a very nanny state issue, but often ABS issues resolve after a run, potentially (assuming FWD) if she managed to turn the front wheels & not the back it could have got itself confused & a run resolved it. You can get a cheap OBD bluetooth reader & a mobile app to read any codes.Just had my Passat on a good run to the Lakes and back. next morning, partner moved the car without putting seatbelt on (auto hold brake doesn't work without seatbelt). I think this threw the ECU so I had all the lights and warnings on the dash (ABS, Traction control, tyre pressure sensors, airbag, everything). Booked it in next week to get it looked at, then yesterday after a short drive they all went and everything is working again.
I think through driving it has fixed itself (i.e. ECU has learned that the fault is over and all is fine).
Do you think this could be a recurring issue or just an ECU brain fart? I don't want to replace ABS sensors/bearing rings if I don't have to. Apparently it's a common fault and the bearing ring expands and interferes with the sensors, which then in turn knock out other things as well.
Agreed, my own fault for screwing my original one up, although even the case on that one shows signs of water, I've located another but the guys away until the weeknd so I'll keep playing with this one, keeps me out of trouble. They are mounted in a completely different place in the kit & I space them off the mounting plate in case any water did get in logically it would drain under it & out the strategically placed holes.with that amount of corrosion, intermittent faults will keep rearing their head. Try and source a pristine ECU, protect from moisture
