I've never done an update on my Neo 1 apart from when I first set it up - I assumed it would tell me if needed!It may have reset itself I guess? It used to show I don’t actually use the app. Maybe I should...
That’s interesting. I don’t normally use it anyway but I didn’t realise it could have a negative effect.
like I said I only noticed the option had gone while trying to work out why my pm won’t pair.
on a side note but regarding the app. Anyone done firmware updates for the neo? I’ve never looked to see if there are any I need to do.
When I first tried to turn off the road feel setting I thought I had to do it in the Tacx Utility app , so i did this and it made no difference. I later realised it was on the Zwift settings (which you're not currently seeing for some reason) and switching it off there instead did work. So I'm not sure whether changing the setting for this on the app will help you - worth a try though I guess.
