I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
And the poor shopkeeper who spent his time assessing the faults and telling you what you needed to do doesn't get a penny for his time and trouble.... Nice?
I am a little bit confused as to how the OP has all the tools, has experience replacing the parts, must have been aware that there was a problem with shifting, needed the LBS to tell them what the problems were, yet will also be checking themselves. Why go to the shop at all?And the poor shopkeeper who spent his time assessing the faults and telling you what you needed to do doesn't get a penny for his time and trouble.... Nice?
I wouldn't even bat an eyelid.... think of how many people say... ''ho...I would at least buy any parts from them, even if I fitted them myself to save on labour. I think I'd be embarrassed not to.
ok...when can you do it'' ... whilst rubbing hands!
Skolly - do you think the OP got good advice? They might have taken time and trouble but, prima facie, the advice does seem low quality, with revenue generation seeming to have undue influence.And the poor shopkeeper who spent his time assessing the faults and telling you what you needed to do doesn't get a penny for his time and trouble.... Nice?
I knackered a my last crankset by letting the chain go beyond 1% worn (I didn't have a chain checker). The crankset had been on the bike for about 2000 miles.Worn chain rings usually go very shark toothed and you'll start to get chain suck. I'd be surprised on a road bike as it takes many many thousands of miles to wear out. MTB - I went through a £50 chain ring in 12 months. PS the teeth are often profiled, so don't take it that they are worn.
How many rings on the crankset?I knackered a my last crankset by letting the chain go beyond 1% worn (I didn't have a chain checker). The crankset had been on the bike for about 2000 miles.
I fitted a new chain but was getting chain suck so I swapped out the crankset and now all is good.
Now I'm checking my chain for wear every week.
All the grit tends to wear the inner/outer surfaces faster than the teeth.Rea[r]d brake pad, easy, just slots in, I have a spare.
Not sure how you came to that conclusion?Skolly - do you think the OP got good advice? They might have taken time and trouble but, prima facie, the advice does seem low quality, with revenue generation seeming to have undue influence.
It could well be a cable problem.Rear gearing - jockey wheels are fine, the Mech does swivel and move OK but it is very dirty. When I try and shift from smallest cog to anything bigger from the brifter it is not functioning - it pulls and clicks. With the mech being stiff perhaps the cable has been compromised. I need to take it apart for a closer look. I also see no reason to replace the mech. I do not like the tiagra shifters on these bikes, they are really hard to work on. I also have the nasty hydaulic converter on the handlebars (see https://www.giant-bicycles.com/gb/defy-advanced-3-2018)
How do you figure? OP has agreed that all those parts need work. Fair enough they clean up the existing parts themselves and get it running but for a mechanic it's surely easier cheaper to replace. Taking the seized mech as an example, I would happily strip and rebuild it myself, I enjoy fiddling with parts, but it would take me an entire evening and about half a bottle of wine so maybe £100 or more in workshop time. A Tiagra mech is what, thirty or forty quid and would take maybe twenty minutes to half an hour for a mechanic to fit and set up? It's just not worth it to ask them to strip it down. For a high end groupset sure, but not a low to mid range like Tiagra.Skolly - do you think the OP got good advice? They might have taken time and trouble but, prima facie, the advice does seem low quality, with revenue generation seeming to have undue influence.
Having said that, I'd buy some of what's needed from the (my) LBS.
Perhaps ill-advisedly, I was basing my judgement on the assertions of the OP: @Rooster1: "I take great care of my bikes. I don't ride and throw in the garage." Maybe @Darius_Jedburgh 's jibe struck the OP's guilty nerve.'Prima facie' the shop has apparently been presented with a 2 year old bike that has received minimal attention and is now presumably not running well, hence being sent to the shop?
Since they have in the past "replaced all these bits" yet take the bike in then I too wonder that. As I said, I would buy some of what's needed from the LBS, depending on the basis of them looking over the bike. Asking what might be wrong and how much it'd cost to put right is normal practice for equipment (not just bikes) maintenance and repair etc. Then it's up to the customer to decide. But it pays to have a good relationship with your LBS: the OP fails to maintain this at their risk.I'm still not sure whether OP has the competence to assess the bike and carry out the work, and if they do, why they took it to the shop at all.
2) try moving the cable from the rear end, if it moves freely fine, if it feel stiff, replace it. 3) then try shifting.
I was referring to replacing the inner cable not the mech!Personally I wouldn't move straight to binning it, although I have been guilty of doing so in the past. A soak in degreaser, and thorough spray with GT85 and re-lubrication of all moving parts and a bit of tensing and relaxing the springs can work out any seizes. Don't forget to keep it lubed regularly to prevent seizing.
Oh sorry! Still, good advice for the mech!I was referring to replacing the inner cable not the mech!![]()
