biking_fox
- Manchester
The light drizzle when I left got heavier. But actually I was just glad to back on the bike after a couple of days away.
Anyone work out why the milk float beeped me?
View: https://youtube.com/shorts/6u7AvcGv9nE?si=OnUfyiIaIzuSfjoh
The lane that is the bus lane and the one he is in are two separate lanes the whole way down and for at least another 600m from the end of my video. The bus lanes stops at side roads to allow other traffic to turn into them.looks like he was trying to pull out on you even though you had right of way as the bus lane ends just past the overtake point ?
There was noone behind me for quite a while and I cannot see why he would be beeping at someone in the opposite direction.Can't even be sure it was you they were beeping.
A single short beep like that tends to be more of a "hello" thing than a "you've done something wrong" thing, which will usually be longer or multiple beeps.
Maybe it's forbidden to ride over a bus lane?
Here (BE) there are lanes with both bus and bicycle markings, and lanes with just bus, where even a bicycle is not allowed.
There has been a time that everything was allowed.
Then no trucks anymore.
Then no cars anymore.
Now not bicycles anymore.
Streets reserved for State transportation.
There are city center streets where even a bicycle is not allowed, first one some 5 years ago, started as only during an annual 2 weeks party, then they made it permanent.
It's how the new normal becomes the normal.
But this is UK, left side of the road, here it's the right side, so maybe I overlooked something.
The standard here in the UK is that bus lanes are also for cycles, and usually also taxis.
It is possible there are some which are only for buses, but I'm not aware of any.
This bus lane is open to cyclists, so much so that it's included as cycling infrastructure on the Bee Network Map.There used to be one in Catford in SE London on my commute, but so many cyclists used it as it avoided a gyratory that they changed it so that cyclists could use it also.
Glad i took a baselayer to work as last nights commute was the coldest in a long while .
Wore a windcheater this morning, though to be fair, after about half an hour I could have ditched it.
