bobzmyunkle
Yes, if this thread is anything to go by, they appear to be both overly complex and extremely dangerous.I just don't think I'd be clever enough for discs.
Wrong. Much easier to live with than canti brakes, more powerful. Ugly on a road bike mind, but my MTB's Guide RS brakes have been trouble free. Easy to bleed, easy to change pads and they don't half stop. This is definitely where disks are needed on MTB's. Disks also make a lot of sense for commuting, cutting rim wear.
They are no more complicated than rim brakes, just different.
This and other recent threads make me relieved that I bought my bike before discs became mainstream.
Discs may well have their advantages but they seem to come with a whole world of mystique and complication that you just don't get with rim brakes. I just don't think I'd be clever enough for discs.
I guess I'll just have to take your word for that.
If I were buying a bike now I'd consider them, but from reading on here they do seem to be incredibly squealy and finicky, requiring special sanding and cleaning of discs, bleeding, extremely accurate alignment, subject to hard-to-diagnose problems and so on.
But I'm speaking from a position of ignorance, and as my frame isn't compatible with discs, it's likely to stay that way for the time being unless my bike gets broken or nicked or something.
If you want mystique and complication, look no further than calipers, cantis or Vs. Cosine error (pad dive) parallax error, straddle wire angles, V-pipe wear, insufficient openeing gaps, pad fade, wet performance, rim gouging, pad pick-up, uneven wear (as on dual-pivots), varying mechanical advantage...etc etc etc.
Discs are the dog's bollocks.
But you don’t know the denominator . There are millions of hydraulic disc brakes in use, and how many posts do you see? No one bothers posting about their disc brakes that just work.
I've got a rim brake bike and a disc brake bike. Is one more onerous to maintain than the other? Not really. I just have to remember which I'm riding when I go downhill in the rain.I have dual pivot brakes so I avoid all that straddle wire malarkey. Rim wear is a thing to keep an eye on, I agree.
A fair point.
But it's all hypothetical anyway as I couldn't fit them to my bike if I wanted to, and I'm not going to buy a whole new bike out of curiosity about a different kind of brake.
first bit of the puzzle solved, it is 180 front, 160 rear
he had picked up a new 160 and you can see from the fit, its a bit short - been out on it and says its working fine, but will get a 180 sometime next weekeven I wouldn't ride that, it could do something unexpected and suddenly lock up
How long do discs typically last ? the one that failed was new last may (9 months) and was down to 1.1 - 1.3 thickness when it collapsed
he will do a big mileage (never counts so no idea mileage) and i'm sure he will race everyone on the commute, he's super fit super powerful, so probably a lot of hard braking, and i doubt there will be much in the way of maintenance or cleaning
apparently the pads were good, i wondered if they had been down to the rivets (i doubt they use rivets but i like than phrase)
I'm sure that shiny section shows its been out and tested
That one looks set up oppositely badly to the one in the OP.
The pads should cover pretty much all of the braking service .
Now, if we move on to threading cables through the head tube, I'm sure I can come up with a much stronger opinion.
Maybe it's the wrong size...
