figbat
Slippery scientist
- South Oxfordshire, UK
The disc does look very thin. But also it looks like the pads were tracking ‘low’ on the disc. Some calipers have a washer arrangement for alignment; could be missing?
This is it in a sentence. He couldn't be arsed to do his pre ride checks, but strangely can be arsed to blame anything but his own carelessness and negligence.Your brother has failed to check wear - don't go blaming something else.
Despite many thousands of miles on many bikes over many years, I've only ever had one rim wear though.![]()
No, and I made that clear on the first page, I know nothing about disc brakes on bikes - simply exploring what might of happened, I only have that rather poor image to go on + a few measurements that will have been done accuratelyPS OP, do you actually have a bike with discs ? Your brother has failed to check wear - don't go blaming something else.
Who is blaming who ? my brother ain't blaming anyone, I haven't blamed anyone !This is it in a sentence. He couldn't be arsed to do his pre ride checks, but strangely can be arsed to blame anything but his own carelessness and negligence.
why ?In the interests of the forum's collective mental health, can we perhaps have a whip-round to buy the OP a ruler?
Oh, OK. He accepts it was his fault then. My apologies.
why ?
For what?
A 6 and an 8 can look similar if stamped on a disc. It's one ot the other and running a 180 20mm spacer if 180 but we don't have pictures of the disk
We're on four pages and op was told it was a worn out disk on page one. But wouldn't accept it.
You can get next day delivery from amazon for a disk. Get a clarkes if not sure.
My road bike has the same sized disc front and rear as does my wife’s. Only our mountain bikes have a larger disc on the front. I appreciate it’s a small sample size though and bikes / brands may vary.Getting back to the disc, I'm thinking it probably is 180, discs are often bigger on the front than the rear (or at least they are on cars and lorries) because they handle more braking force due to weight transfer - the same will be true of bikes - 180 front 160 rear could be the case, as an earlier poster pointed out.
That's a tenuous argument. Stamped text on the non-swept section does not wear away. Further, just because you can have a bigger disc in front doesn't mean there was a bigger disc in front. It could have been 180/160 - 160/160, 160/140 or even 140/140.Getting back to the disc, I'm thinking it probably is 180, discs are often bigger on the front than the rear (or at least they are on cars and lorries) because they handle more braking force due to weight transfer - the same will be true of bikes - 180 front 160 rear could be the case, as an earlier poster pointed out.
Discs may well have their advantages but they seem to come with a whole world of mystique and complication that you just don't get with rim brakes. I just don't think I'd be clever enough for discs.
