JuhaL
and almost quarter of Lee.And the 15KG heavier than mostThat's nearly 3 stone!!
Through a load of nested vlookups that are more confusing than the Magic Roundabout in Swindon, I've re-jigged the spreadsheet so that it now displays tables for both handicapped and non-handicapped results. that way you can choose to look at the table that shows you in the best light - so well done @Marino.g and @Brusgaard!I think he means on the left hand ZP column, it isn't in time order. That would mean two different name sorts.
Being at a cat boundary is tricky in these handicap races I think. Your logic holds true I think as long as you're able to hold with the pack of the higher cat for the majority of the ride. Having to go with the A's yesterday meant that I had to try stick with them, at least as far as the next pack of B's up the road. By that point (end of lap 1) I was totally buggered, not able to go any further with the A's but now in a pack of B's that were dropping behind the faster group of B's ahead.Yeah but our mini league is being ranked primarily on actual race time (rightly so I think as the handicaps in these races are quite a blunt tool). And apart from Lars, all the other B's in yesterday's race were a few minutes quicker than the C's. Worth the gamble that you can stay with the Bs and benefit from the faster overall speed
More like 1/2 to 1/3, He's like a twig stood next to meand almost quarter of Lee.
Through a load of nested vlookups that are more confusing than the Magic Roundabout in Swindon, I've re-jigged the spreadsheet so that it now displays tables for both handicapped and non-handicapped results. that way you can choose to look at the table that shows you in the best light - so well done @Marino.g and @Brusgaard! View attachment 451225
Will do Monte. I'll add any new Cyclechatter results to the spreadsheet after tonight's races (and any from future weeks).Hi Peter,
Can you add me onto the list - Carlo DG - CAT C
See you online @ 6 this evening.
Just throw that big book away for good and you’ll lose a couple of stone!
@bobinski, you’re a very bad influence on this group!
Don't frigging blame me
You are all as bad as each other.
Im a strong C on that course and likely a mid B if its not too lively![]()
Good luck later @MonteHi Peter,
You'll fly down towards St James palace![]()
