Zwift Chat
JuhaL
Liking my Garmin integration. I should have done it earlier. I'd read that Garmin wouldn't accept indoor riding and use it to calculate all sorts of other metrics, recovery, V02 max etc. But it does work 😁
Some says that Garmin is clunky and awkward but I don't have nothing bad to say. For me it does the job very well. I'm not professional so I don't have any special demands what Garmin can't do.
C
CXRAndy
Lincs
Neither do I Juha
I like the body battery feature, now has calories burned from indoor riding
Norry1
Warwick
..... still on the TPV trail.
I worked out the virtual gearing feature today and it is excellent. You don't need any special kit - just enable it and then use the += key to up the gear and the - key to reduce it.
Another interesting bi-product of using the virtual gears was that I put the chain in a straight line and kept it there throughout. The display then showed that my Trainer was often showing a higher wattage than my pedals - again just shows how many watts are available by looking after your drivechain and also getting the best chainline. I always "knew" these things but TPV is really bringing it home to me.
Whorty
Gets free watts from the Atom ;)
Wiltshire
Chap who won our 180-350 race today. His ZRS is still over 50 points below mine (his is 277). Seems his ZRS score isn't rising very fast - are his 'floor' and 'ceiling' capped due to his low power?
It was a flat course (RGV) - no idea how he managed to hang on with an average of 143 watts? I was barely hanging on at 215 watts. Very strange, any ideas?
I was 11th out of 52 on the road, quite pleased. Wasn't sure I'd make it over the aqueduct with the leaders, but just about did that. Got dropped on the final roller before the finish. Managed to beat 3 others over the line though to hang on to a decent 11th (9 on ZP).
alex_cycles
Oxfordshire
mjd1988
They say only about 1% - if that's correct then it's a lot of development and cost for a very small % of riders. I suspect though it's currently higher than that as too many riders have too high a seed/ZRS and they want to reduce it to a value that reflects where they really are (I'm definitely in that category).
Thing is though, it's still easy to tank ZRS - just let the pack go in the first minute, then ride hard as a solo rider for the rest of the ride - result is a decent effort in power/HRM but a poor finish position as the pack will go much faster than a solo rider. This is undetectable as getting dropped from a pack is par for the course in racing.
I still think Zwift are trying to solve the wrong problems that they have created with ZRS.
1% is a massive underestimate id say. Even on a micro level, if you are in a group of 2 sprinting for second last, will you try as hard?
Whorty
Wiltshire
Agreed. Seems I'm not the only person who has identified the flaw in ZRS that can easily be used by someone wanting to control their ZRS score - screen shot is from the Zwift Insider post, where someone seems to be doing exactly what I said earlier.
Definitely a popcorn moment as Zwift try to fix ZRS without admitting they got it wrong :popcorn:
alex_cycles
Oxfordshire
The anti-tanking measures are not yet active as far as I know, but I think they will be fairly soon...
C
CXRAndy
Lincs
End of this month or is December?
IrishAl
** Full Time Pro **
N.Ireland
Looks like there are many ways to throw a race. Hopefully they find a way that rewards good performance (race position or power) with a good boost in ZRS score, and any poor performances result in a slow rate of decay in ZRS.
Whorty
Wiltshire
Indeed. But they suggest it's 'minimum effort' they are looking for, i.e. cruising in a race, but it's easy to tank a score and still have a high effort.
One way is, from the start pens, instead of pushing 450 watts to stick with the pack, push 250-300 instead. Lose the back wheel and the pack flies off. I'm still exceeding my FTP and HR goes up. I then hold watts at a normal race average for the rest of the race - I've given a normal race effort, but come in last.
Could also race hard for 30 mins, then get 'dropped' by the pack due to a lapse of concentration (we've all done it for real, I've been dropped on descents!), then we tempo to the finish. Result, finish down the results and lower the ZRS.
People will do this and I can't see how it's easy to detect as it's normal in races for riders to get dropped.
Only my personal view, but I think this is a waste of time Zwift trying manage this as it's easily manipulated (I could be proven wrong, and I'll admit so if the anti-tanking actually works). Just accept some people will game the game and concentrate more effort on fixing the initial seedings would be money better spent.
Whorty
Wiltshire
Indeed.
I watch with interest to see how this pans out but given their success to date I'm sceptical :popcorn:
alex_cycles
Oxfordshire
You're missing the point. The idea with minimum effort is not to PREVENT tanking, but to make it MORE EFFORT.
Currently it's a piece of piss to waltz round at the back of the Tinies and dump a tonne of points in just one hour.
Whatever system you have there will be ways round it for the determined. It's not foolproof and it's not designed to be. It's just there to make it inconvenient.
