Legs
usually riding on Zwift or up steep hills...
 - Staffordshire
This was only halfway up!
Looks like I've killed another wahoo tickr HRM , corroded battery again . What's the consensus on a reliable HRM for both indoor and outdoor riding .
Alex will I be dq for no HRM tomorrow night if I race ?
No I don't use any fitness type devices for anything other than cycling , I think my HRM does start up so it may register to get me to the start ,if don't it not the end of the world if I don't race .Have you a wrist watch with HRM ? that should work if you set it to broadcast HR. Won't be as accurate as a chest strap but will comply with the requirements.
Both my last 2 wahoo HRM have failed due to sweat ingress into the battery compartment so a more sealed unit may be the answerI have a usb charged hrm. I tend to have to charge it about 5 minutes before every race for some reason but it's still more reliable than any lithium ion battery one I've had.
I had a lot of trouble with Garmin HRM's so went with Wahoo, which has been fine and I am very sweaty, the strap on the Wahoo disintegrated so I use an old Garmin Strap with the bit cut out between the studs, never had trouble with sweat ingress which I find surprising reading all the trouble others have had. My lad has Garmin which he is very happy with, so it looks as if they have improved since I ditched them,I went from Garmin over to Wahoo HRMs but rather quickly moved back to Garmin after several failed Wahoo Tickr’s. One under warranty but second failed just outside the warranty period. I did briefly use a Magene but it wasn’t giving a reliable output - good enough to pass the Zwift sniff test but I knew it was off. I’ve been on the same Garmin now for the last 24 months or more with no issues (touches wood)
I killed loads and now have a Coospo. One thing it told me to do is always take the HR bit off the chest strap. I do this every ride now and it has been spot on so far. May be the same is needed for the Tickr?
