That sounds too drastic for me! I need a slow burn else I'll just put it all back on again afterwards (and probably bonk on rides!)I am back to 1500 calories a day to shift my last 5kg
1-2 kilos could be put down to normal daily fluctuations. 8kgThat’s a good watch. So many were 2 kilos over and the Cofidis rider 8k over Strava weight ! Bit embarrassing for them and Zwift
. He wants e-sports to succeed so this has really put his nose out of line (I agree with him as there's national jerseys on the line now).So long as no one forces me to get on the scales at the ToC I should be ok1-2 kilos could be put down to normal daily fluctuations. 8kg
Shane was quite vocal on the 'fugg orf you cheats' track. He wants e-sports to succeed so this has really put his nose out of line (I agree with him as there's national jerseys on the line now).
How much have you lost?I am back to 1500 calories a day to shift my last 5kg
I can lose 1.5kg during a ride easy just through sweat. I've weighed myself a few times recently and been 79kg dead after a ride1-2 kilos could be put down to normal daily fluctuations. 8kg
maybe I should use my post ride weight on zwift as I am technically riding at this weight for some of the ride lolThat sounds too drastic for me! I need a slow burn else I'll just put it all back on again afterwards (and probably bonk on rides!)
Do you stick to the 1500 even if you burn1000 extra on the bike or does that earn extra for the day?
MyFitnessPal gave me 1,800 calories per day but added on all calories burned exercising, so I was eating 3,000 some days and still losing weight.
Spinning vs Grinding ... an interesting youtube video ....
I think the most efficient cadence rates can vary from person to person quite a lot. Even the pros vary massively - they don't all use the same technique. E.G compare Froome's climbing style to Contador's and they're very different but both very successful. The difference with the pros is they have coaches and lots of time to train and experiment to fine tune what works best for them, whilst we generally go with what feels right for us. Personally I'm more of a grinder than a spinner and that seems to suit my physiology best, and without proper coaching etc. I'm not going to try and change things too much. I know neither you or this video are doing this, but I'm really sceptical when I read articles saying we should all increase our cadence to a particular RPM to be more efficient - I think (like most things) it's more complicated than that.
I've noticed a slight quirk with the Neo with regards power and cadence. If you get out of the saddle to grind a bigger gear, your power initially drops quite a bit, before increasing as it should. If you drop down a gear and spin faster, the opposite happens in that your power initially shoots up before settling back down, even if your cadence remains the same. I assume the change in cadence is initially tricking the Neo into thinking you've increased or decreased power significantly, before it realises what your "speed" is and adjusts appropriately.
I'm definitely like you, I feel more comfortable as I get tired on a climb to grind more. Efficient or not, it's just what my body allows and I can deal with. Also I like to get out the saddle as the road rises, even if only for 20 seconds. It just 'feels' right.I think the most efficient cadence rates can vary from person to person quite a lot. Even the pros vary massively - they don't all use the same technique. E.G compare Froome's climbing style to Contador's and they're very different but both very successful. The difference with the pros is they have coaches and lots of time to train and experiment to fine tune what works best for them, whilst we generally go with what feels right for us. Personally I'm more of a grinder than a spinner and that seems to suit my physiology best, and without proper coaching etc. I'm not going to try and change things too much. I know neither you or this video are doing this, but I'm really sceptical when I read articles saying we should all increase our cadence to a particular RPM to be more efficient - I think (like most things) it's more complicated than that.
I need to move to Norfolk
