<Tommy>
Illegitimi non carborundum
- Camden, London
Tommy doesn't like squealing brakes as i found out on the DD![]()
Not a big fan of clunky gears either as Bob found out
1 or 2 have said they had a problem but majority no problem at all weight weenies on the sl6 disc thread
Ill give them a light sand and clean swap pads front to rear and ill get a spare set of pads incase its contaminated
Im like u there bike must be silent no irritating noise just the sound of the wheels on the tarmac
I forgot about that. They still squealing?
Not a big fan of clunky gears either as Bob found out![]()
A fix for squealing brakes on cars is copper grease on the back of the pad. I don't know if that is applicable to bicycle brakes but to me it would be worth a shot. Just a thin layer don't over do it.1 or 2 have said they had a problem but majority no problem at all weight weenies on the sl6 disc thread
Tommy it was built by local bike builder who been involed in racing for over 30 yrs still racing he hate disc brakes aswell i can take it back to him no problem but he off to the dolomites tuesday ill have a go myself tomorrow rebleed realign good clean then if still problem ill take it to him monday
Going to order a new ultegra rear mech. Problem went away for a few days but has reappeared. Been looked at twice and consensus is worn/damaged rear mech. May as well buy it then though preferably attached to a new bike![]()
Yep still the same, I've recently changed the pads but I'll change the rotors as well before france and give it a good going over.I forgot about that. They still squealing?
Can you put the link up for that tool for the callipers sounds ideal and the disc versionDon’t get me wrong. Most if not all mechanics have forgotten more than I’ll ever know! It’s probably near impossible to know a bikes running smooth until you’ve put a few miles on it I guess. But once you’ve sussed how to sort it yourself it much easier to stay on top of the creaks and squeals.
I did just think of something else. I bought a tool a while ago to help get the correct shoe in for calliper brakes. Basically a piece of plastic that you sit between the break pad and brake surface to set the gap correct. While googling for the part I saw something similar for disc brakes. I’ll see if I can find it tomorrow.
That noise you had on the TOC Bob sounded like a worn cassette. The chain seemed to be jumping when applying power. How old/many miles?
Can you put the link up for that tool for the callipers sounds ideal and the disc version.
Im much like you Tommy i like to potteron my bikes, got a neat trick for putting in front derailleur cable
What i use for the disc drake on the giant is a business card over the rotor to align, tyre lever to push pistons back and an adjustable spanner for rotor trueing and i have the giant spot on
