7.3kg without pedals could get it down to 7kg or even lower ill see what deals pop up on some rovals clx as they r light dor clinchers
Better add some lead for TOC
Andy im getting a lot of brake squealing on the rear brake ive gave it a good clean with ipa still squealing any tips
I have several wheelsets with expensive to cheap rotors fitted. The most expensive rotors squeal the most, cheapest almost silent. What type are the pads resin or sintered? Try the other type, also rub the pads on flat surface with sandpaper to roughen up the surface . The last option is to find a long steep hill and use the brakes with lots of braking effort to super heat the pads and rotors to bed them in.
If you get good with applying the brakes you can make it sound as if an ambulance or a police car is coming alongIt has a benefit that people will notice you and your lovllo bike![]()
Tommy doesn't like squealing brakes as i found out on the DDOk you won't like this. It's either the pads or rotors.I have several wheelsets with expensive to cheap rotors fitted. The most expensive rotors squeal the most, cheapest almost silent. What type are the pads resin or sintered? Try the other type, also rub the pads on flat surface with sandpaper to roughen up the surface . The last option is to find a long steep hill and use the brakes with lots of braking effort to super heat the pads and rotors to bed them in.
Edit. Warning The rotors will be scalding hot, don't touch them
Sometimes I haven't been able to sort noise, so live with it. It has a benefit that people will notice you and your lovllo bike![]()
its really annoying my giant only squeals in the wet then its only a few seconds
