star84
Regular
- southend,Essex
i guess no one is having the same gear issue as me
What a very odd looking riding position.
I finally got round to cleaning and greasing wheel hubs today. Found it quite easy, next job is checking the bottom bracket.
Also changed the brake pads to these http://www.chainreactioncycles.com/Models.aspx?ModelID=55814
I'll post some pics when I get round to doing it.I'll be interested in your BB check. Do we know what the model of bottom bracket is?
i guess no one is having the same gear issue as me![]()
small front, large rear and i get a rattling noise aslo tried small front with secound to largest rear same rattle or cranking noise and it frequently slipped making it impossible to ride on that gear kind of ruined my ride but when i changed back to the middle front/middle rear it fine so only the middle and largest front/ middle and smallest rear works fine on my bike...thanksStar84, let's try and help you: to do so we'll need to define the issue bette. You've mentioned the first gear not working and just not feeling right so far. Are you hearing noises? Are you in the small cog on the front and small cogs on the back with the chain angled? What precisely are you doing when the problem occurs? What terrain are you on when it happens?
If I can just butt in here for just the one little post? Well just to welcome myself to the owners club now I've got mine!! LOL
Just to say I just got my Triban yesterday morning (I only oderedit from france on last friday evening) and have had some little problem setting up the gear changs for the front chain wheels as the small return lever tends to really stiff.
That said I did just manage to let my self have a short ride of a about 3 miles to get used to the gear positions on the brake levers as not ridden a drop bar roadie for thirty years It does feel strange. Though I can't get over just how quick this bike really is (light too even a 60cm frame) compared to my big Trek 7200
That said Ive yet to drop the wheels out and whack some grease on the wheel bearings any thing else I should look out for?
I will post pics soon. Oh I have changed the pedals to Shimarno A520 doubled sided SPD's
Taking the pressure off the pedals when changing will make a huge difference, keep pedalling forward gently. This is even more important for the front mech.I noticed the lever is a bit stiff. I'm going to give it a shot of GT85 soon; also the faster one is going when changing may make it easy for the front mech to move the chain...(?)
.i have jus looked at it properly and the noise is deffinately from the chain sliping from the rear largest gear to the rear second large gear with the front gear on the smallest...the chain cant seat on the rear largest gear this is the problem how can it be fixed ?
Can you not go back to the store for a replacement?I could just buy a new wheel set.
