andyoxon
- Punxsutawney-on-Thames
Yes, you're right - re. locknut - that occurred to me too after a while.I think they are meant to be more than finger tight - otherwise I could see potential for movement of cone nut slackening off, I know the when I undid mine they were much tighter than finger tight... rear wheel the same, but more fiddly... (I'm no expert on this matter, it was the first time I had done them as well).
rr - will read the SB article - thanks.
This...
Quick-release hubs are trickier to adjust, because the quick-release mechanism compresses the axle slightly when it is tightened. If you adjust the cones so that they feel just right off the bike, they will bind up when you tighten the quick release. You must set the cones so that there is a little bit of play when the hub is off the bike, or when the wheel is installed with the quick release just barely tightened.
