will be at the end of summer. have heard cruds are good ??Has anyone put/or going to put mudguards on their Triban? If so what do you reckon would fit/be good?
I have SKS Chromoplastics on mine. Very tricky to fit with lots of adjusting required. Had to shorten the guard stays in order to get them to fit but once this was done the guards fitted very neatly.Has anyone put/or going to put mudguards on their Triban? If so what do you reckon would fit/be good?
I have managed to get SKS chromoplastics on but it is a bit of a hack with 25mm tyres. If I was still on the 23mm tyres it probably would have been easier, but for me there was not enough clearance getting them between the brakes & tyres. Still looking at a better way of anchoring them on properly - may try doing what I am meant to do with them via the brake bolt bracket "thing" which might make them more stable rather than how they are currently attached (which involved the pannier rack!).Has anyone put/or going to put mudguards on their Triban? If so what do you reckon would fit/be good?
Here you go:
Brilliant. That is extremely helpful. Thanks to you and Brian for the great pics. The chain seems to be the correct length, however, I noticed that the front deraiuler needed to be adjusted outwards when the chain was on the largest front and smallest rear, as the chain was slightly tapping at the front. Think I have got it sorted now after some trial and error, and will be going for a little ride soon to check.
As for the comments about my skills as a vehicle techy; Just because I'm good with cars, doesn't mean I am automatically aware of all systems on all things mechanical. A road bike that I have just layed out money on is not something to just go spannering on. I like to understand how things work. People who go at things not knowing how they work are pretty poor technicians. That's how you break things. A good technician will learn about something inside out, before they start working on it. And again, I had never been educated on the gear mechanicals on my bike, so I would have liked the assistant to do so.
); if you aren't using mudguards then watch the amount of grit that sneaks in through the slot on the seat tube (just under the seat post clamp). I have been wondering about my seat height again (more on this later) so took the opportunity to take out the seat and post and clean it up ready for a refit; not nice, could feel the grit on exit, there was fine brown sediment left in the tube and around the clamp. All cleaned out and greased up now to stop further gunk getting in ... an easy bit of fettling that's best done sooner rather than later.Video dosn't show you much mostly how to fit peddles and handlebars, don't know about shims got some small bits of plastic but don't know what they are for.Hi there. Got my T3 a couple of weeks ago. Love it! Mine came with nothing. I am told that there should have been some shims for adjusting the brake levers and also a video(?). What else am I missing? No mention of a free service or safety check either. Should I have one of both included? Cheers Richard
