Apologies for suggesting the obvious, but it isn't the crank hitting the end of the front mech cable is it? I had that once and it took me ages to realise as it only did in when on one the big ring! Just bend the cable in a bit.I'm still getting a clicking noise from my left crank, anyone know what I should do next? I've taken the pedals out and greased the threads and it seems to go away for a few miles and then it's back again.
Same here but only in the granny ringApologies for suggesting the obvious, but it isn't the crank hitting the end of the front mech cable is it? I had that once and it took me ages to realise as it only did in when on one the big ring! Just bend the cable in a bit.
Also, check your seat clamp is tight, (post and the rails), I was convinced I had bottom bracket creaking when it was just creaking from the seat rails.
Stick the with it. Today I got to the top of one of my regular hills and realised I was still on the big ring (normally change to middle ring half way up)! I'm finding I'm spending much more time in the higher gears than I used to 6 months ago and using the granny ring less and less. There's still a couple of hills round here where I'm still grateful to have it though.Same here!
That big ring is some murderous shizz!!
Nothing wrong with a big ring.
