Havoc6
Yeah whT size psot would I need to replace it
Ok , mine is 29.85mm , hope that helps
Hi, im new triban 3 owneri got it for 150£ second hand in very good condition. Because its my first road bike i have few qestions:
1. its 63cm frame (im 186cm) and ity feels ok. is there a point to change/modyfy it?
2. what is best tyres for commuting (puncture proof)?
3. what brakes should i buy? (standard ones are not the best; crank, swiss?)
4. what grease should i buy? ( LITHIUM EP2 ?)
Many thx for any help
Hi jaz have you tightened the crank on the BB.I'm still getting a clicking noise from my left crank, anyone know what I should do next? I've taken the pedals out and greased the threads and it seems to go away for a few miles and then it's back again.
Hi Antnee have you tightened the lock ring up fully, if yes you may need a spacer.hi all.
Im just in the process of fitting new SRAM PG850 11-28 cassette to a shimano R 500 new wheel and on tightening the cassette locking ring see that some of the sprockets are still slightly moving? Is this perhaps because they are not seating correctly upon the next sprocket .i.e the bigger ones further away from the locking ring I was advised that I would not need any spacer on equiring when buying the wheels and the locking ring does seem to be gripping slight Help any one please as I have to fix these as yesterday when out broke a spoke on the T3 and now have a bad twist in the old Triban wheel rim which I will have to get fixed (as not sure I am up to the task of wheel truing) It a good job I got the new wheels when I did as if I can get this cassette on the new wheelset I will be off riding again.
Anyone have any tips?
