Phred1812
- East Devon
Yes. Undo and remove existing cartridge, remove screw, slide out old block, slide in correct letter of new one (left or right - they are clearly marked), put in new screw, put brake block pack in place. remember they need to bed in, though some people simply take a little sand paper to the block & clean up their rims - I didn't bother.These are now sold out on this site unfortunately but available elsewhere. Do these pads fit into the T3 brake blocks without modification?
Much better. Mine have been on my bike now for +3,000km and are still going strong and I can out brake my OH on his T3 by more than 10m in the wet, which is worrying me regarding my OH's safety who is still on the original blocks and does not want to change!Just bought these Swissstop pads on Wiggle, for £22.49 including free postage. Hoping they are better than the standard spec pads which seem to be made of cheese.![]()
They use the same blocks and just slide in (though 1 of mine was exceptionally stiff to get in & out and needed a little subtle persuasion) and screw into place.I saw these on Wiggle too but am not sure whether I need the rubber pads only or the entire brake blocks. Are they compatible with the blocks on the T3?
8 mins should be long enough to test - did you stop?Just fitted Swisstops and cross levers to my T3. Going out to test...
Swissstop GHP II Flash Pro Road Bike Brake Pads - Green - they have been on my T3 for around 3,250km (through winter) now and there is still at least 1/2 of that left in them yet. Stopping power in all weather is excellent (ps - they don't look green so it won't clash!). They are pricey at £24.95 but that includes P&P and they will give you plenty of confidence you are going to stop once they bed in.
http://www.ebay.co.uk/itm/Swissstop-Flash-Pro-Road-Bike-Brake-Pads-Shimano-Green-/360581873471?_trksid=p5197.m1992&_trkparms=aid=111000&algo=REC.CURRENT&ao=1&asc=14&meid=6628221292135703703&pid=100015&prg=1006&rk=1&sd=360581873471&[/quote]
Thanx sat nav have just orderd mine![]()
In what way are they slipping Kookas? I had a problem with a bit of movement of one crank on the spindle shortly after buying the bike. All I had to do was tighten up the bolt that secures the crank with an Allen key. I have had no problem since.
I'm thinking of getting a Triban for my daughter. Can anyone advise what the difference is between the Triban 3 Red and the Triban 3 white
.... apart from the colour and £20.
Thanks
Only the side of the cone facing downwards gets pressed against the rotating cup in the hub. You could mark the worn segment of each cone and rotate the axle so that segment does not face the ground when you clamp the hub into the frame. This will minimize any further damage the worn segment of the cone might do to the cup.Hub post
Rear had been over tightened and took some effort to loosen everything. Bearings ok but damage on the cone. Bit light on grease. Took it all apart and cleaned and regreased and its running ok, much better than previous. That cone damage concerns me though but they are 20 quid wheels so I will replace when they don't work...
