Tea?
classic33
Leg End Member
Self-levelling....
makes a big difference..
This was yesterdays fail..(what I intended to make)
(it's made in two parts (halved)
It's a QFH antenna body...
it needs supports, quite a technical piece..
I don't know how to do supports (yet)...
Saves you having to do the job.
That's not yours then? If it is, it looks good for a failure.
Doesn't the printing plan include supports. Presuming here you got the plan, not started from scratch on yer own.
You'll get there.
Bobby Mhor
Behind You
Owdo
Resistance is futile...
Dreamland had a hold on you?
Can buy try, and yerself...
You'll get there.
Yeah, it's a handy feature...
You get the initial file but you have to 'slice' it and somewhere is an option to insert supports but to be fair that is a bit of a doozy to print, I'll get there.
I'm good at Maneki-Neko,
(a good test piece),
made a couple of holders for a pair of handhelds plus a holder for an SDR unit,
that'll be enough for a while I think.
I use files that others have created,
program I have then creates the file to print.
Some good work out there.
Catching up on early morning ball...
no early game today as on the west coast.
classic33
Leg End Member
Must save a fair bit head scratching for folk as well.
No hints/ideas on where to put supports given?
Printed once only, or will you be needing more.
Can you buy that piece on it's own, or is it part of something larger.
The "Money Cat"!
Has it brought you any?
How well does what comes off the printer hold up, it's not a "be careful with that" piece.
I've seen a model of "Hush-Hush" being printed at a local show. All the numbers worked out from drawings, 2D to 3D. Got to admire the work done to manage that.
You winning or losing?
craigwend
Grimpeur des terrains plats
Another storm in ?
https://www.bbc.co.uk/news/articles/c0lwg32w998o.amp
Bobby Mhor
Behind You
The "Money Cat"!
No, but it allows some else in the household to do retail therapy :laugh:
Seem okay although PLA can weather but dunno if I'll put anything outside...
I'll work on the supports thing at some point.
Oh, I've an orange, black and a blue cat on the desk LOL
classic33
Leg End Member
It brings you luck then.
That's another thing it's favour then.
Yer noggin is in for some serious scratching. Or will it be easier than you're thinking.
Especially afterwards.
You beat your orange Money Cat black and blue!
Bobby Mhor
Behind You
Red, it's says on the spool, RED..
Is it? :laugh:
Not the clearest but that's RED...
left back - handie holder (or cradle) followed by the good luck bear, next, still warm, is I'll post once I've set it up (dongle and filter base) and a SDR where the SDR unit stands sideways....
classic33
Leg End Member
Is it? :laugh:
Wonder how orange would look alongside it.
Looks good, and yer appear to be getting the hang of it.
What's the baseplate size on the printer?
classic33
Leg End Member
Baseplate is 235 x 235 mm but print size is 220 x 220....
It's a budget printer
Not big enough to print "Hush Hush" then. Around 3" too small.
Does it do what you want it to do, that's the important part. There'll always be bigger and better one's out there(More bells and whistles).
Bobby Mhor
Behind You
It's a budget one....
It'll do for what I need it for...
odds and ends....
Baseball about 9ish tonight so night sorted....
