After a good few weeks of stagnation I'm happy to report some more progress!
A while ago on
@Gunk's recommendation I popped my head round the door of local shop Warlands on my quest for a replacement bracket for the rear mudguard. After a pitying look toward the bike from the owner (or perhaps he recognised it as having been dumped across the road from his shop before I found it) I was sent on my way with a used one for the princely sum of a quid
Since this job requred a bit of effort and skill while offering plenty of scope for cock-ups it was left for a while, until this morning when I awoke early and uncharactistically motivated; spurred on by a fantastic dawn that promised a day of glorious weather.
Out into the fresh morning air and the back end of the bike was stripped; chain, wheel, panier rack and brake caliper off; leaving the tatty rear mudguard hanging on by a single stubborn bolt at the chainstay bridge. The bolt had a thin slotted head with limited access, and after breaking a chunk out of my finest piece of spare-broken-hacksaw blade trying to hold the bolt steady I cracked out the Dremel and cut some slots across the nut and bolt; which got it all moving with no bother
Once off the sorry state of the guard could be seen in all its glory - half of the plastic covering already torn off, the rest tatty in places and harbouring some light corrosion of the stainless guards where it had been damaged and retained moisture..
The site of the old, broken bracket:
The leading edge of the guard where it bolts to the frame:
The next seeming eternity was spent peeling of the covering f (if I was lucky), or more often than not painstakingly picking it away in areas where the adhesive proved stronger than the material itself. This was helped by a bit of warming over the gas ring; sometimes to the detriment of my fingers
With all the plastic removed the guard was washed, dried and the remaining adhesive residue scrubbed off with an old sock and some degreaser. While it was off I had a crack at knocking out a bit more of the smackhead damage; using a dolly lashed up from a bit of rotten wooden baton and the guard separated from the doorstep beneath by the faithful old sock again..
Finally the guard was waxed; looking a lot better than when I started:
Next I moved onto the frame, which was also a bit grotty:
The back end of the bike got a bit of a wash and scrub with an old toothbrush to get the worst of the crap out of the nooks and crannies before also being waxed to afford a bit of extra protection.
Next I had a crack at the bracket; first straightening it out with pliers and an adjustable spanner before giving a bit of a working-over with a soft-faced mallet and the famous sock on my doorstep anvil to try and knock the tighter kinks out, with some success..
This was offered up to the guard, marked and bent as accurately as possible in successive goes with the adjustable spanner again, until it was a reasonable but loose fit on the guard. It's far from perfect but given my limited facilities and experience with such stuff I don't think I could have done much better:
While the panier rack was off I took the opportunity to strip it and work over the rusted chrome with some 0000 wire wool and oil, with pleasing if not perfect results. Here's the rack bracket after my last effort - cleaned up a lot better than I'd expected although in some areas it's clearly too far gone with the chrome having flaked off in sizeable chunks..
As usual once tidied everything was waxed, with a little thick oil dropped into the joints to try and give some corrosion protection in these areas.
(Ctd. in next post
