Paint is pretty good actually. There are a few chips and scuffs plus a bit of paint loss under the chainstays and on the dropouts, but it's survived remarkably well, considering. I'll just go over the bare bits with some clear nail varnish - no one will see them unless the bike is tipped upside down.
I was dealt the worst possible hand with the graphics, as it's a junior bike (I know, this gal is a bit undertall), and those tend to be more flamboyant on the paint job side than the equivalent adult bikes. So a light cadmium red bike, with navy, dayglo orange and acid lime green. Sunglasses time and then some...
The bike is from 1998 btw.
Before (flash has muted the colours some, but you get the idea):
After - well, the almost bare frame:
I think it looks a lot better as a plain frame, don't you?
I did a bit of nosing around, and the bike also came in a bright green with yellow and orange graphics. I think I prefer the red.
P.S. I love the mix of burgundy and cream on yours. It's cleaned up really nicely.
That looks like a nice little score for a kid's bike (which as we all know usually see the worst neglect / abuse) and I agree it looks so much better without the stickers (and really tidy too for the work you've evidently put in). Graphics designed for kids in the '90s were never going to wear well but the colour looks pretty nice in isolation
Glad you like mine - I love the colout too and FWIW I think the paint makes it look a lot more expensive than it was (the white head tube echoing the Randonneur of the same era which - by current used prices - is worth about four times as much).
I've made some more decent progress on the Routier today. After deliberating for ages over where to source a chain I bit the bullet and went for the more costly but conveneint, known quantity of one from
Decathlon (which is just down the road) for eight quid.. bringing the total spend to a little shy of £30 so far.
The short trip was made on the Raleigh and typified by oppressive heat and humidity, the bike making an array of perplexing and concerning noises, and the overwhelming desire to issue a firm backhand to the muppet stood next to me in the bike bits aisle whose face mask coverage was limited to only his chin - wtf is wrong with people?
Because the bike was an unknown quantity I elected to size the chain using the accepted method rather than simply relying on cutting it to the same number of links as the one that came off; a learning experience as I've only ever replaced chains on bikes I've had from new so not needed this process.
I followed the first bit of
this Park Tool video; revealing that my chain was clearly too long.
Not much forward RD cage displacement on the big/big combination..
... while the cage was folded right back on itself on the small/small sprocket setup:
In addition to this less-than-ideal orientation the chain was also very sloppy with next to no tension.
I played about folding the chain to simulate a shorter length than the 114 links fitted; suggesting that losing two link pairs / four links total would be about right:
However, as previously measured the chain has worn to about 2% oversize; which in terms of length is the equivalent of having a little more than two additional links / one link pair. I elected to fit the 114 link chain as-received and once sure probably remove one link pair to give 112 links remaining.
I was reassured to have my suspicions confirmed that Decathlon's chain is a re-boxed KMC item...
...which after unpacking was chucked into a jar of paraffin, given a good shake and left to sit to remove the sticky factory packing grease while I got on with other bits of the job.
The unfeasibly greasey chain was split and removed, the rear wheel pulled out and the bike precariously propped up to allow access to the drive components; which were saturated in water-based degreaser, left to sit for a while, scrubbed and rinsed. This process was repeated numerous times until the 30-odd years of caked on grease and grit had been removed as best as possible. Only one paragraph to describe; a couple of messy hours to complete in real life.
At some point during the above process the new chain was removed from the paraffin, drip-dried and chucked in a pan of wax / moly powder mixture on the hob and left to cool; turning occasionally
Once the drive components were "clean" (and the resultant spatter removed from the rest of the bike as best as possible) it was all reassembled with the new waxed chain; confirming that the replacement was indeed a bit long so a link pair was pulled to bring it down to 112 links total.
I'm generally really pleased with how it's turned out - the extreme RD positions now look a lot more acceptable (if still a little sloppy in the small/small combination; not that I'm likely to use this), and the transmission parts so much cleaner
Tbh I don't really think the pics really convey how much grime was removed from the chainset and freewheel; thankfully this won't be a problem in future thanks to the lovely waxed chain
I found the RD to have a fair bit of slop in its mounting and jockey wheels, although thankfully this doesn't appear to affect performance.
Given the chain wear and array of nasty noises I was a bit concerned that I might encounter slippage with the new chain, however a quick lap or two round the block proved this to not be the case (at least so far). In other great news I reckon the number of sinister sounds eminating from the drivetrain have decreased by maybe 75% which is great
(Ctd. in next post)
