Oh yes, Max is finished bar a couple of nice but not essential tweaks (waiting for parts supply situation to improve) and I've had lots of fun riding local back roads, gravel trails and farm tracks. Good for muddy winter roads too. Not the lightest bike in the world, but very forgiving on rough surfaces.
And it's a bike that turns heads wherever I go.
And
HERE is the thread you were after...
Excellent - looks like it turned out splendid
A pitifully unexiting update on the Routier.. Saturday saw a return trip for eggs and a bit more nancy-gravel action; only for the whole thing to be ruined by a slow puncture when I got back (well, along with fatigue, wind-chill and general misery.. but I digress).
This is the first puncture I've had on this bike and not something I've been looking forward to fixing. I took the chain off to make things a bit simpler, inverted the bike on some wooden blocks to protect the tat bolted to the handlebars, cracked out the spanners and waggled the really-too-large tyres past the unfeasibly-close-fitting mudguard at the chainstay.
Once the appropriate bits had been separated the culprit was found to be a good, honest thorn though the tyre and tube. Tube patched and back together, I noticed the rear wheel was far from aligned with the downtube. I figured this was because I'd dished it wrong (during all the brutality to make the horrifically-abused rear wheel serviceable again) and subsequently skewed the wheel in the dropouts to centre it in the mudguard at the front.
I got out the spoke key and worked my way around one side of the wheel tweaking them loose by half a turn, then tightening them in a similar manner on the other side. This was repeated (with adjustements at the dropout as appropriate) until a total of 1.25 turns had been administered..
The wheel now seems parallel to the length of the frame; however is now noticeably offset to one side. Basically everything seems on the pish; the wheel offset to one side relative to the seat stays and to the other relative to the mudguard - the rear stays of which I've had to significantly straighten on one side and bend on the other to get clearance.
As much as I love this old bike and respect the old-skool craftsmanship of Raleigh; I can't help but think that this might be a bit of a friday afternoon special - perhaps after a particularly sustained liquid lunch (something that's supported by the pished caliper mounting hole in the fork)..
I also found a randomly-excessively-worn patch on the rear tyre - odd as the brakes are physically incapable of of locking the rear wheel - as much as I'd like to do some skids to impress the ladies.. I wonder if this is associated with the pished wheel; but I can't really see why this would only affect one spot.
Anyway, it is what it is. I might give it a run to the shop shortly to acquire a (fermented, cereal-based) dinner. If I don't post again in the next few days please assume the hateful contraption has killed me.
