Afternoon from a sun lounger in a very hot and sunny Porthmadog
Is anyone using, or recently moved to on the the classic double edged razors which seem to be coming back into fashion? I get dense stubble and suffer really bad razor bumps and burn and have been told and read about how they are supposed to be a better way of shaving once you have mastered the technique.
I'm now 32, been shaving for best part of 18 years and I've tried every modern razor out there and every pre and post shave regimes going but so far all have proven to be expensive gimmicks
Cheers, Kev
Not tried the double edged but I would like to
I used to get terrible razor bumps and rashes, my neck was very very sore
I read up on shaving, and it has made a difference.
Wash your face with hot water, get your face as warm as possible, don't shave upwards only down. Wash with warm water after the shave and use after shave
The rash and bumps are from small infections, this is from shaving too short and getting water in there. If you wash with cold water it closes the hair follicles and traps in dirt
Then use moisturisers, about an hour before shaving I find best
