Reynard
- Cambridgeshire, UK
Erm, chaps... It's the allen bolt that's stuck.
If it won't turn then WD40, Duck Oil or similar.Erm, chaps... It's the allen bolt that's stuck.![]()
My 80s Phillips Premiere was a Raleigh in all but name.The BL parts bin had nothing on Raleigh,I think they invented 'badge engineering', so many of the bikes from the 80s and 90s were virtually identical apart from paint jobs and a better model was often down to fitting 'better' components to the same frame.
1st rule of engineering..... if in doubt give it a clout
I'd never hit the stem with the forks on the ground, I'd do it with the front wheel in, my method would be to undo the centre allen bolt a few turns then whack it with a copper/hide mallet, leaving the front wheel in means you can grip it between your legs whilst you wiggle the stem loose.
I *should* have a set of long-handled allen keys in the garage, but can I find them? I've been using my multitool (not ideal, I know), and I simply can't get enough leverage.
I usually use a suitably sized ring spanner slipped over allen keys when I need more leverage. If I need to stop a fork turning, I'll jam a length of 4 x 2 in between the fork blades up at the crown end and wedge it against the downtube or between my legs. If I need to get really brutal I'll fit a wheel axle or a bit of studding and nuts and washers across the fork dropouts to try to stop anything twisting out of alignment, but I'm probably a bit more of a brute force merchant than you......
