Reynard
- Cambridgeshire, UK
Looking great now the stickers are off. Are you going with plain Raleigh stickers at any point ?
Actually, I'm rather tempted to leave it the way it is. I just really like the colour.
Heh, well I do have a set somewhere, but for the life of me, I just can't find them! Now the magic trick is this - if I buy another complete set, then the other ones will suddenly appear right in front of my nose.![]()
I think that frame looks great......good job on that. Cork grips and a blond Brooks would go very well with gumwalls tires, too. For someone who says they aren't very skilled you are doing very well. Those minitools are ok for adjustments but nothing beats a proper tool. Using a bit of pipe or a spanner is like having a breaker bar. After loosening the bolt I'll bet the wedge will require a little force as well. Still, the results will be worth it.
No. Just bite the bullet and get a new freehub wheel and cassette and be done with it. In doing two rigid 26" MTBs, this saved hours of faffing. More choice with gearing, too.Is it even worth bothering? It's not a tool I'm ever likely to need again. And is it worth getting a replacement freewheel if I was going to upgrade the wheelset and drivetrain anyway? Aaaargh!!!
Edit: as well as future-proofing as far as spares go.
This depends on what space you're referring to. You are quite likely to have to bend it to 135mm, but if that's no biggie, then the wheel is likely to be capable of 7/8/9 speed, so the world is your tasty mollusc. But 7-speed is likely to be the least number. I still have those 8-spd shifters which will do V and other brake types...What size cassette can I fit without running into space issues?
