Reynard
- Cambridgeshire, UK
This depends on what space you're referring to. You are quite likely to have to bend it to 135mm, but if that's no biggie, then the wheel is likely to be capable of 7/8/9 speed, so the world is your tasty mollusc. But 7-speed is likely to be the least number. I still have those 8-spd shifters which will do V and other brake types...
Careful choice of 8-speed cassette would give you a really nicely spaced 12-30 or up to 34 if the RD can handle it, but 30 should be fine, I would have thought...
The rear dropouts are 130mm, so bending them to get a new wheel in isn't an issue, I don't think. I was thinking more about chain fouling, what with it being such a small frame.
I had been thinking of an 11-28 7-speed matched to a 44-32-22 triple, which would give me a similar range to the hybrid, but if an 8-speed cassette will fit, then there won't be such big gaps. It's still at the planning stage - that's why I was trying to get the bike up and running so I would have a better idea of what was really needed.
Those 8-speed shifters do sound nice.
The wheelset I'm after is currently listed as out of stock, which is a bit of a pain. But I think I'll get the wheels and tyres and then just slowly go from there.
