Anyways, as promised, a couple of pics.
As you can see, the front brake callipers cleaned up nicely, other than the retaining bolt for the straddle cable. And no, your eyes are not deceiving you, the cable for the rear derailleur HAS got that almighty kink in it. And it stays that way, even under tension. Someone's obviously had a good yank of that at some point - probably in the effort to free the chain. That cable is very frayed where it comes out of the outer and into the RD as well.
And the rear brakes and cable hanger. The rears were more tatty than the fronts, and it shows. But again, perfectly functional. Although admittedly they are rather fugly. I did see some lovely black and red cantis for sale, but at £94 for one set, I think not!
Today's work on the project involved buying a set of tyres. I did go for the Schwalbe Road Cruiser Plus in the end - at £10.99 each they were better than half price at
CRC, so that frees up a good chunk of the budget to spend elsewhere.
Plus the old bars have been measured. They're 560mm width and 25.4mm diameter. Lots of places online seem out of stock or only have the 31.5-ish mm diameter. I may as well take the bars to my LBS and say "have you got something like this in?"
So far, I've spent...
Bike £25
Brake cables (inner & outer) £4
Brake blocks £10
Inner tube £5
Wheelset £57
Tyres £22
So that's £123 so far on the project, and
@All uphill 's £200 spend on that touring bike looks like where I'm going to be at in terms of the actual build. That's still *well* below half the cost of buying a new bike with the spec I want, although I've had to give up the idea of suspension forks and disc brakes. The former is no great loss, as to be fair, a rigid steel bike with decent tyres will be lighter and do an equally good job for the riding I have in mind. And there's far less to worry about on the maintenance front.
How I spend the rest of the budget depends on where I go with the crankset once I've decided the number of teeth to go for. I could go cheap and get a unitary construction triple for around £15, or spend a chunk more and get one that comes apart. I'd prefer the latter route, but that might well depend on a) what I decide on in terms of teeth, b) what's available and c) can I find a used one in decent nick? Maybe a call in CC's wanted section will be worth trying...
I've also spent £28 on tools (crank puller, freewheel remover, allen keys), but to be fair, good tools never go to waste, and are always a sound investment. I'm of the mind to get tools as and when I need them, rather than splurge on a kit and end up with a bunch of stuff I'll never use...
