Real man shaving.
I use Connaught shaving. Well, when I say 'use' since I went to a DE about 4/5 years ago and bought a brush and a Merkur something or other I've only had to order from them a couple of times. A selection of shaving creams and a couple of blade sample packs.
Only thing is with the sample packs, by the time I've used them all I can't remember which ones i liked most. The present ASCO ones are horrible though - only lasting a couple of shaves at best.
And +1 for the twist out alum bloc. I may have to eventually replace it due to usage instead of breakage.
May seem a big initial outlay compared to the multi-blade offerings, but when you can get 65 blades for £12.50 instead of what 1/2 dozen? I like the lack of waste with them too, both aerosol foams and blades. Didn't our throwaway culture start with razor blades?
GrumpyGregry
Here for rides.
Yep - mine shattered on the tiled bathroom floor. Replaced with a RazrRock, which is an alum block in a tube, like a twist-up deo stick. Mind you, I use a styptic pencil these days to deal with any nicks as I find it far better than an alum block in that respect.
Stypic powder and a cotton bud for nicks round ours. Bloc Osma is more a post-shave treatment though it does have stypic properties. (and tastes sh|t, so don't use it if you're gonna get kissed.)
GrumpyGregry
Here for rides.
All this talk of shaving makes me want to try a real razor and a bristle brush etc.
Mach 3 turbo blades don't last long and the money spent is crazy.
I guess buying this lot will cost more up front but work out much cheaper in the long run?
Someone recommend me a shop or website I can buy the original shaving equipment please
www.traditionalshaving.co.uk
though I often just use amazon and fleabay to buy Feather brand blades in bulk
+1. I tried out a couple of tester packs from Connaught before setting on Astra Platinum, with Feathers for special days. The choice of blade and razor is about as personal as a Brooks B17 or a Charge Spoon....Takes a while to find out the combination that suits you. They also do tester packs of soap and I tried these too before settling on Taylor's Sandalwood. But I might try the Almond too - but I'll stick with the B17 on my Hybrid, thank you.....
JoeyB
Go on, tilt your head!
I started thinking the same after reading this, I would also be interested to know where everyone shops.
GrumpyGregry
Here for rides.
oh come on. Nothing compares with Feather. Massive vfm as they stay sharp for what seems like forever.
I ride B17 and Spoon. But I'll only use Feather. Go figure.
I was expecting something special after reading similar opinions on Feathers. Can't say I was all that impressed, they're ok, but I get similar results from Gillette's.
vernon
Harder than Ronnie Pickering
Meanwood, Leeds
You can't beat a blow lamp and B and Q paint scraper with Swarfega as an after shave. It's a once in a lifetime experience. ;)
