Although the original tape wouldn't hold air, it does look like tubeless tape to me.This is the tape that was originally in the rims:
You don' t buy a "bluetooth ready" device, you buy a bluetokth device. And the same with all those other things you list. There was a time when "HD ready" televisions were common, and that always meant you needed an external. HD source.Well that's just my point. You don't buy a bluetooth ready device expecting you'll have to buy extra stuff and do extra work to make it bluetooth. Or buy a dishwasher ready tupperware that can't be washed in a dishwasher without extra bits. Or buy an electric ready car and realise it doesn't come with a battery. Or a skydive ready parachute that doesn't....
At least DT Swiss seems to agree with me: 'All DT Swiss wheelsets are tubeless compatible and the ASM versions come tubeless ready, equipped with tubeless tape and valves.' Surely my wheels are only tubeless compatible, not tubeless ready. I'm surprised that you weren't surprised to find your tubeless ready wheels not ready for tubeless.
Some manufacturers certainly do. But if it were normally expected, they wouldn't be making a point of it in their advertising.I won't keep banging on the same point I've already made several times about what tubeless ready means.
However I did some research and a lot of manufacturers do provide tubeless ready wheels with tubeless tape.
'Fulcrum®’s “Tubeless Ready” products are ready for this changeover, with tape already in place.'
'ASM versions come tubeless ready, equipped with tubeless tape and valves.' (DT Swiss)
'Included | Tubeless tape & valves, spare spokes, axle adapters' (Hunt)
'Tubeless compatible (Valve and Tape supplied)' (Hope)
'Includes Bontrager TLR rim strip, TLR valve stem, internal cam quick release' (Bontrager)
I'm confused too. Just bought some Hunt wheels and I THINK they have tubeless rimtape. But now I'm not so sure ?
Just by the by I did my second ever mount of a tubeless tyre this weekend.
The first was a long messy faffy swearing session, so I was prepared for a frustrating experience. However it went as smoothly as one of those smug gits on YouTube. Pop pop, sealant in, valve in, done.
Unfortunately I forgot to line the maker's name up with the valve. No I'm not going to take it off and re-fit it but it is going to annoy me.
Is there a practical reason for doing it?Does help as a guide for locating objects in the tyre. Take the tube out and find the hole.I don't quite get thisIs there a practical reason for doing it?
If you're using tubes, yes. To help you line up a punctured tube with the tyre to help locate the pointy thing. That's the theory. Although, I don't recall ever actually doing that because when I remove a tube I normally leave the tyre in place on the rim.I don't quite get thisIs there a practical reason for doing it?
Assumptions are the mother of all f*** ups. Now you know why that is.If I'd bought 'tubeless ready wheels' I would presume that anything they came with (and that includes rim tape) would be, err, well, ready for tubeless tyres.
I'm using 45mm WTB Raddler tires on a 23mm WTB rim. Yep same manufacturer for rim and tires, yet they were a right pig to get on.
In my opinion it's been worth the aggro though, since I put them on I've had two years of faultless off-road riding, including several long distance trips. I've noticed stains from sealant on the tires from time to time, so I've had punctures, but the've all sealed with no noticeable loss of pressure.
This is with the proper tubeless tape:
Visibly there appears to not be much difference, but the original tape wouldn't hold air and yet the green tape will.
