classic33
Leg End Member
Walling the city off, allowing no-one out?So far only one thing has worked to curb covid worldwide
Just this week I think they started using them. Other placers are looking at using them too. Some companies are already using them. I Remember reading.I'm not sure how accurate the calibration values are for each phone (yeah I know they exist). I'm not even sure how long the advertise is and how often it's repeated.
I did hear that Singapore got very frustrated and launched a single device for people to use.
And what was "clearly asked" was "Just another example of "I'm alright Jack, sod you". My enjoyment is more important than your health. Explain why you feel this is the case" when I don't feel that anyone's enjoyment is more important than someone else's health, contrary to the implication.Nothing has been "made up" about you. What was clearly stated was "The minority have made it worse for the majority. As is often the case.".
I think it's using the Google/Apple exposure API, so pretty much all the apps that work will be using the same method.Yes It is a bit out without knowing the error margin it's hard to say just how much and how many false positives it though up.
Any idea what other counties have used with similar coded based app ?
I think many will stop using it after the first or second time it tells them to isolate and test anyway, even if it was a justified alert but negative test.If it keeps giving you false readings once too often. Many will just stop using it.
Anyone know the story behind Huawei phones being excluded?
As for our app as winter comes and we have phones berried in thick coats and at bottom of bags. Can’t see that helping things either.
"Explain why you feel this is the case" was the question. You seem to feel that pubs should be excluded from restrictions, but refuse to say why.And what was "clearly asked" was "Just another example of "I'm alright Jack, sod you". My enjoyment is more important than your health. Explain why you feel this is the case" when I don't feel that anyone's enjoyment is more important than someone else's health, contrary to the implication.
Yes many new builds have paper thin walls at best. Unless you can set up reminders how many are going to remember to turn them off at work ? Most just but them in a locker and leave. Leaving your phone in the car may don't do it much good either.I think there will be the reverse problem. Neighbours having phones shouting at each other and clocking up half an hour's worth of risk. That's the worry among others of having such a high rating for up to four metres (half of 2 metres).
Others are saying because they are more concerned with measuring the time exposure vs other factors (which can be done more accurately).
You are supposed to switch the app off on the home screen e.g. if you're behind a barrier or in PPE.
No, I don't feel that. However, I would like the restrictions to be evidence-based and logical across activities, not all this obsession about pubs while ignoring bigger problems.You seem to feel that pubs should be excluded from restrictions, but refuse to say why.
Someone just asked if me he'd read this right (No he's not bored he's looking stuff for work) so I looked it up.
The Health Protection (Coronavirus, Restrictions) (No. 2) (England) Regulations 2020 under linked households appears to say that once you form a linked house you can't change it or form a new one even if you are no longer linked to the 1st. So you better not have family fall out then![]()
