Since the bottom bracket based eccenter tensioner arrived at its front position so not able to tension further, and with short worn sprocket teeth, last sunday 3 october I replaced the chain with a new one, while keeping the worn sprockets.
The drivetrain all of sudden went completely silent.
I replaced with the same model motorcycle chain Regina 420 Urban orox, a 1/4" wide chain, delivered greased with a white substance.
The first one I mounted, early 2020, thus held out almost 21 months.
About lubrication then, my subject here, empirical confirmation: since I ceased putting a drip oil on the rollers, the wear rate drastically reduced. The days before the replacement last sunday, I rode hours through heavy wind and rain, causing the chain to become wet despite my cover. The rain (just like oil did) "cleaned" the internals of the chain, drove particles out, which in turn allowed the links to separate more.
So this proves the theory yet another time: worn off (and/or external?) particles sit between chain parts mating surfaces, and stay there due to friction, until a lubricating liquid reduces the friction so that they become mobile and are driven out.
Since my chain rain cover isn't a complete cover, far from, just some small angle on the vertical, rust stays a problem, being also the reason that after my first try of this motorcycle chain, I was forced to lubricate.
So I now tried something else: a thick grease that I bought some years ago in a metalware shop, dirtcheap 1.5 euro each, 2 canisters, labeled as rust protection and antiseize of aircraft and other outdoor application door hinges.
I bought it as bolt thread rust protection, for ex for the 6 bolts of my rear disc cog. It lubricates "a little" - it's too viscous to flow into inner parts of the chain links.
I smeared the grease on the chain using a finger.
It's now a week, have been in wind and rain again, 2 times, no rust.
Unlike last year, where I had to retension the new chain quite alot the first ride after oiling as rust protection (and implicitly also lubrication of internals). I had to retension just a little bit over the entire week.
I'll see what it gives. The lubrication or whatever that white smear is for, is and will stay thus solely the one delivered by the manufacturer of the chain.
The first next question to be answered is how long the worn sprockets will last further.
It's the third chain for the Velosolo 1/8" chainring, and the second for their bolt on disc cog. The disc cog is likely the first fail, by a tooth breakage. Since the chain pitch is now the one of a new chain, likely the load isn't divided anymore over several cog teeth, just one.
But that's unsure, since it's a heavy chain and as before, something is out of center causing chain tension to fluctuate quite alot during a cranks rotation. Fact is that the drivetrain, despite the very worn sprockets, runs totally silent. I again surprise other cyclists, even when resisting the pedals to slowdown, which had become so noisy that people looked backwards to see what was coming after them lol.
