Chain lubrication, the balance of pros versus cons
silva
silva
Belgium
Somewhere in 'Bicycling Science' there is some information on transmission efficiency and IIRC a dry, rusty chain was still pretty efficient compared to alternatives and while worse than a new chain, it was not substantially worse (I suspect belt drives were not included and it's likely the alternative was shaft drive). Will see if I can find it later.
It's interesting, but I didn't stop lubricating my chain after reading that.
Having said that on my shopping bike the intervals between lubing are often very long- one or two times per year and wear is not a concern I have at all. Trips are short & frequent, often done instead of walking, chain is pretty chunky- likely it will not be replaced in the next five years, longer in all likelihood.
Rust (internal not external) is also a wear aggravator of same magnitude as grinding paste from oil and dirt.
It's mechanically much weaker so it wears off quickly, so it doesn't fill space to prevent chain becoming longer.
I have seen alot rain the past months. It has happened that some rollers showed brown spots. In the past I put oil on these to prevent further rust. That was unneeded - the rust gets worn off after a few km's.
So avoiding rust is as important as avoiding grinding paste.
silva
silva
Belgium
Agreed
The OP is also measuring chain wear due to having to re-tension the chain on a Fixed gear. Not exactly a scientific measurement as the slackening could also be caused by rear wheel movement and Freewheel/Chainring and roller, wear.
Moot points, but in any case, I can see no viable reason not to clean and lube a chain!
https://www.sheldonbrown.com/chain-wear.html
- My rear wheel has a one place fixed mount. No horizontal dropouts. As said: the chain tensioning is done by a bottom bracket based eccenter.
- You first say fixed gear, then you say could be caused by freewheel wear.
Talking about moot points!
The other points, and actually all even if had been true, can be eliminated from the equation, because they were/would have been present with, and without lubrication, so on both sides of the equation.
silva
silva
Belgium
+1
haven't washed a bike in well over a decade.
But it's important to keep the drivetrain and gear shifting maintained/clean/kept lubed.
.... AND cleaned.
Because of this equation:
lube + dirt = grinding paste = more wear than metal on metal.
Dogtrousers
Kilometre nibbler
I missed this thread. Do I dare read it from the start?
I'm tempted to press "ignore thread" and run away and pretend I never saw it.
.... AND cleaned.
I once bought a bike from a bloke who commuted along the Swansea/Mumbles coastal path and thought that using plenty of oil on the chain without cleaning it was a good idea.
The cassette rings were like ninja stars from the oil and sand mix.
silva
silva
Belgium
Carry on sharing @silva You can never tell where your experience and derived conclusions might find a receptive landing place.
This topic is about a choice for the case (my case) of a to sand / dirt / external wear particles exposed chain:
1. lubrication and alot cleaning work to avoid increasing instead of reducing wear.
versus
2. no lubrication and no cleaning work and a wear less than 1. without cleaning work.
I have had now several months a chain running dry.
Yet, the eccenter tensioner moved forward much less than before, with some cleaning of the staying mounted chain and some targeted lubrication.
So the idea of 2. didn't have to come from the other side of the ocean - it was the most obvious next option.
And since the rain cover, so rust no game ruiner anymore, that option became a reality.
And so far, it proved.
The real test is ofcourse one from the start: a new chain, and see how long that running dry can keep it in the running.
For ex, in autumn, lotsa wind, colder so chain dries up slower, condensation, it's quite possible that rust will still end the test due to force oil.
Maybe I can improve that rain cover, so that the chain is more protected against wind from the side. But there is ample room. Ideally it should be some separate addon cover parts that I can easily remove when needed.
The current rain cover, as you can see on the pic, is like that. It's mounted with knotted inner tube rubber. I can just flip it up / away from the chain.
silva
silva
Belgium
Oil on a dirty chain is mothers best kitchen recipe for wear.
But it's also oil that leads to that dirty chain.
So it's a circular story.
I broke that circle right there.
