GuyBoden
- Warrington
In my experience, I've found that Just lube and no real chain cleaning leads to a build up of black gunk.Thank you for getting this thread back on its sprocket (straying off into Chloride Induced Stress Corrosion Cracking (use 316 bolts not 304 in a maritime operating environment)).
Can I ask what you mean by "cleaned" and "regular" (aka frequent?), Guy?
Oil and wipe; Oil and wipe. How much cleaning effect do think such a regime has? If done daily (say) is that "over-lubrication"? Would it be worse than not lubricating.
This is my usual approach:
!.) On a nice dry Summer day's road riding, I find a wipe down with a rag, a bit of lube and then another wipe with a rag is suffice after a few rides.
2.) On a wet, muddy day, I'll wash down with a garden hose nozzle, then a wipe down with a rag, a bit of lube and then another wipe with a rag after every ride or two depending on how muddy the chain.
I've been using industrial Fuch chain Lube for the last year or so, it seems to do the job.
https://shop.lrt-lubricants.co.uk/products/fuchs-chain-lube-500ml-aerosol
