Gillstay
I doubt many EV are as slippery as the 0.26 cd vauxhall calibra we all wanted in the 1990's!🤣🤣🤣
Best check out the new Audi on Harrys garage.
I'll believe it when I can buy a 500 mile range EV with a battery the size of a fag packet, but not until then.
E Tron? 0.27 with w mirrors 0.28 without ....🤔
55 Wh/l in 2008 to 450 Wh/l in 2020,
That doesn't surprise me. If you test drive a VW ID4 and a Tesla Y, you would buy the Tesla Y. Every time.Reading more that VW sales of EVs in Germany are really struggling compared against competition. They are losing what market they had.
55 Wh/l in 2008 to 450 Wh/l in 2020, with the biggest bulk of that improvement coming between 2017 and 2020.
I like my ID4, but once you get past the funky headlights and mood lighting you are left with a car with a very poor, often nonsensical software system that doesn't receive regular updates of much use.
For example:-
When you approach the driver's door of a Tesla, the Tesla senses the card in your pocket and knows it's you .It adjusts the drivers seat and wing mirrors to your preferred position. The car's configuration is set up for you and is ready to go. The radio station that you like is playing. The air con is set to your preferences etc. Google maps is ready to go.
When you approach the driver's door of an ID4, it wakes up. You sit in the drivers seat which is manual adjustment only (unless you have top spec). The screen loads once you touch the power button or push the brake. After 5-10 seconds, the software boots and asks you to confirm which user is driving the car. Then you have to tap on a disclaimer notice - both interactions with noticeable lag. Then you have to manually adjust your mirrors - even the wing mirrors which are digitally controlled. It does set the air con to your preference. But not the radio. For that, you must tap on the menu button, then audio, then favourites then scroll left, then choose your station, then press the menu button again to exit the menu.
Then you press app connect to connect to Android Auto which can take up to 5 minutes.
The experience is frankly horrible in comparison, and begs the question as to why VW don't appear to have a software user group. The only real function that the user profile has is to lock all other users out of being able to use the mobile app to check charging, set air con etc.
There is so much missing from the ID4 when compared to the Tesla. The Tesla has an automatically opening boot - on the ID4 that's for top spec only. The Tesla has a huge well for cables etc, the ID4s is tiny.
The only thing I like better about the ID4 is the seat comfort.
There is a scroll button on the steering wheel but it's not very easy to use and doesn't move between your presets, only between "all radio stations" which as it is DAB means that it can take many many clicks to move from say Radio2 to Magic.Well, if it takes multiple 'software' button presses to change a radio station... good god.
For example:-
