I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
Pythagoras.
EDIT: Actually Pythag and vectors of force.
I wouldn't have thought that your brakes would have time to overheat going down the Beacon would they? Not that I have any knowledge of brakes, but just to note that it's only about 1.5km long, and follows about 6k of gradual climb, and possibly a view-admiring stop at the top, where you won't have been braking at all.I never really found out for sure. The tyre was in good nick but afterwards there was a gash in the sidewall, close enough to have been caused by rubbing on the block over time. I didnt think that was likely but I don't entirely rule out schoolboy error for sure. I assumed I'd hit something previousy and hard front breaking caused the failure. I generally run my tyres at 100 psi.
I doubt it was overheating as I used to speed down the straights and only brake to kill speed prior to the corner, then accelerate out and it's all over in 2 minutes. It's a hill I've done a thousand times but now I'm like Bambi on ice which actually feels more dangerous but hard to overcome.It's always a good idea to keep data and photos of accidents for geeks like me. I now don't know if the tyre blew off from too much pressure or whether it burst from a weakened casing.
A good tyre, inflated to about 90% (lots of variable factors play a role here) of its maximum pressure can blow off if the wheel gets very hot from braking. By very hot, I mean too hot to touch after you've come to a standstill. Manufacturers know this and obviously keep the max recommended pressure well below the theoretical maximum.
A quick burst of braking heats the tyre far less than long slow dragging.
WRT braking and indicating right, surely the simple solution is to have your brake levers setup with the front on the left as per our friends in the continent.
Most of mine are like this; and an added benefit is that you can change to a lower sprocket more easily as you brake to a stop at junctions.
So do II want my strongest, most dexterous hand controlling my most important brake.
Well, I guessed it couldn't be that simpleAh, someone is paying attention. I was getting depressed there.
No, it isn't. I take it you are responding to the 2 and 2 scenario?
The answer is 2.82. I'll give you some time to chew on it. However, most people guess 4 and ride as if it is 4 even if they don't know the answer. This one isn't instinctive.
Ah, now, I deliberately made that guess without checking any other replies, but now I see the words "Pythagoras" and "vector" I do think I've got it, by jove!Well, I guessed it couldn't be that simple
I do know that 2.82 is 2 times the square root of 2 - is that getting close?
Alan
