Having plenty of far more important things to do today I elected to sort the pedals on the Brompton, having seen some corrosion around the RH item and figuring they'd probably benefit from a clean and refit with anti-seize grease.
For reference the RH pedal axle is 15mm the same as the wheel axle nuts, however with both pedals having a socket in their rear / inside face I elected to use a 3/8" breaker bar and hex bits; straddling the bike and standing on the pedal while I precariously tugged on the bar with the opposite arm.
Perhaps unsurprisingly from the corrosion present on the crank the RH pedal turned out to be loose, while the LH item was somewhat seized; going with a bit of a crack after soaking in paraffin while I dithered with the other one.
RH crank with signs of fretting from the loose pedal:
Cleaned and waxed:
RH pedal as-removed; seems there may have been some scant form of lubrication upon assembly. It cleaned up nicely with some paraffin on a toothbrush, but I forgot to take an "after" shot..
LH crank arm pre and post clean / wax; note the damage from incorrect / hamfisted folding of the pedal; some of which I'm probably responsible for..
LH (folding) pedal, which apparently didn't have any lubrication when assembled. I was impressed to see that the small amount of paraffin half-arsedly bled into the threads from the rear appeared to have made its way through the entire length of the threads in the 10-20 minutes it was left.
Sun Race / Sturmey-Archer branded 6203 cartridge bearing.. looks pretty sturdy which is a good thing since the pedal housing appears peened around it; making it irreplaceable.. which is shoot.
Fixings..
Once cleaned it all went back together with some copper grease; torqued up to 30Nm.
I guess that's one less thing to worry about
Cleaned and waxed:
Fixings..
