Oooh - I might get some of those anyway, but I just do them to "that feels about right" not too tight. As you say 'nip' them.You could get 'crows foot' spanner heads for your torque wrench
There is an additional leverage so this formula needs to be used to work out actual torque
Or just nip them![]()
30Nm for all my pedals. Grease the threads and then the back of the bolt when fitted, to minimise galvanic corrosion. Like Andy, never had an issue with taking them off.
I'd never let a bike shop mess around with my beauties, and take pride and pleasure in knowing I've put them together from scratch - tightened every bolt, pressed the BB, tensioned the spokes, adjusted the gears, etc. Will be no different for the new frame. You want it done right - do it yourself.
When I fit pedals, I cover the threads in (lots of) copper grease, and just ever so lightly nip them tight. Pedals self tighten by their opposing thread to rotation. There is no reason to fully tighten a pedal.
I've never had a pedal even when on the bike for 5+ years not come undone.
I prefer to use a longer lever to apply torque rather than hitting a short lever with a dead blow hammer.
Some pedals are Allen keyed for fitting, which is fine but try and get those with a larger socket, less chance of rounding the Allen key. Those with conventional flats, use a narrow, but proper spanner, not the cheap bicycle pressed spanners
guy tried every tool to hand ... final attempt was a breaker rachet in the Allen slot ... the pressure shattered the metal Allen fitting.
So you've been regularly exercising for over 23 years than?All the Gym equipment reinstalled. Cleaned the storage dust off, wiped down.
Oldest piece is 23 years old, walking/running machine still going strong.
Out of interest: How are you managing gym and cycling? I do it too and it's becoming harder the more I try to cycle, obviously. Recently started doing leg days again - very difficult to weave those in without completely compromising your riding.
The conventional wisdom is to do leg days on your hard cycling training days - bike in the morning and gym as much later as possible the same day.
I have been meaning to get back in the gym for a while but it hasn't happened yet.
Interesting, that's (kind of) what I did recently. Not because I gave it a thought - but because that's the only way I saw possible.The conventional wisdom is to do leg days on your hard cycling training days - bike in the morning and gym as much later as possible the same day.
Unfortunately, family and work don't allow me to space things out - so I did a hard race, got off the bike, and straight into the gym to do squats.
As for non-leg days, I always do the gym first and then get on the bike. I don't think it's affecting my performance there.
Still figuring out how to include leg day activities so they would count towards my training load. I was thinking that if I do 10x90kg squat, I could register that as a 10s 900W sprint. Does that make any sense?
