Zwift Chat
Del C
Horley
That's out of the way :B)
I tried to stay with the big group as long as possible, seeing that the fractured packs were tiny behind. Alas not, I found myself marooned between groups for a few several minutes. Eventually group of 4 then 5 formed, with a strong pair of Canyon riders leading. They tried once to break our pack with a big sprint attempt on one of the primes. All it did was get me a new PB :biggrin:. I paced Petit ok(PB), slightly panicked when I could see loads of groups gaining as I neared the top. I put in a big effort a few times to group up with riders in front on the downhill-it worked. I stuck with this group contesting the sprints . Slightly died 400yds from the line as you start to climb Petit, again!.
Del C was in a group just ahead of me-Nice one Del :hello:
As ever video coming- I know you lot cant wait :laugh:
That was a fast start today. I was ok until about 8k in. A small gap and that was it. Out the back, but got in with a group of 8 that then became 9, and that stayed together all the way to the line.
I’ve done every stage so far. Legs are tired, but the endurance still seems ok. I’ve contested every sprint, which I don’t always do, but the FTS points here make it worthwhile. I think my last Pave sprint today was a bit of a token effort really!
C
CXRAndy
Lincs
I think you were in the group that came off the main bunch about 10 secs after me. We could have ridden round having a chat :laugh:
Peter Salt
Bittersweet
Yorkshire, UK
Here you go Casse Flamme Rouge stage 6
View: https://youtu.be/b4Rs3Ucmn2E
You and your imperial measurements, Andy ;):laugh:
Painful way to drop off the back like that - I reckon if you had just 10 more watts to give, it would keep you in the blob at least until the sprint, if not the aqueduct.
Good to see where the finish line is - thought it was a bit closer (before the first hairpin).
mjd1988
Ah flip just realising it's two laps of cases pattes not sure I'll have time to Complete that. Looked at the early rwb league. It's cat enforcement but I can enter cat c? @Brusgaard I see you are racing it, should I enter b anyway or should I enter the lower cat....haven't had the option before and still showing as a b on zwiftpower so a bit confused
mjd1988
I'll maybe go in B just in case. May not make the start line in any case
Brusgaard
Über Guru
Skive, Denmark
Category Enforcement is not related to ZP. But you should join B if your ZP says so IMHO.
