Cheers fellas. I figured cutting the holes out would save a bit of weight - not that I plan on moving it around too often. But it also did come in useful to help with assembly although that would still have been possible without.Great work alan really. The base plate in particular looks absolutely flawless. Did you / why did you cut the holes into it?
I cant see, turbo feet blocks. Beware of full power usage, you could fall off the whole board- dont ask![]()
None fitted Andy...I was thinking the weight of me plus the turbo would make it unlikely to shift in use but I’m guessing you’ve experienced some fun and games there 😄
Fore aft movement im guessing is around 50 to 60mm travel though I’ve yet to put any pressure on it to date. I’ve used a 5inch inflatable ball either side for the rocker cushioning.
As for going into business making them I’ve got a spare chrome plated rod as the steel stockist would only sell me a 9ft length but apart from that I’d say it would be a long wait for anyone wanting one as I’m not the most proficient with the tools and the paint was cheap as so it took about 4 or 5 coats to get the coverage right 😴 I’d say I’ll be able to sell on the rod to someone local.
