Zwift Chat
C
CXRAndy
Lincs
Actually Paul Enve have some wide rim aero wheels which are designed specifically to 28mm. The profile smooths out the bead joint. This and the fact that running 50-60 psi allows the tyre to roll smoothly over all the crappy surfaces. Once over 28mm the wider tyre frontal area impacts on aero gains
JuhaL
One of my friend have a Canyon Ultimate CF road bike and now he have a cycle-cross tyre on that bike. Don't remember is it 32mm or wider but very versatile bike for both gravel and road.
Ming the Merciless
There is no mercy
Inside my skull
I'm not sure anyone claims wider tyres are more aero do they?
Depends. There’s a guy who has come from F1 and it is not just frontal drag. There is also what is calling the sailing affect which pushes the bike forwards depends on wind angle. So depending on rim / tyre interface it can be more aero depending on the wind yaw.
Of course you can always get a smaller diameter front wheel which will be more aero but less of the sailing effect.
But then bike aero claims have to be put into context as most (other than recumbents) do not put the rider in an optimised aerodynamic position. As this picture below demonstrates if you are focused on the bike tyres first for aero you are looking in the wrong place.
502997
bridgy
Cheddar
So putting aside rolling resistance, are you saying that a 23mm tyre on an aero rim which is also just as optimised to smooth out the bead join would be less aero than a 28mm (or 25mm) tyre/rim combo?
bridgy
Cheddar
Yes good point, and no I'm not focussing first on tyres for aero gains - just querying the claim that wider tyres are more aero (all other things being equal). Worth making the point you did though
Milzy
You beat me to it. Was on GCN show about 2 years ago.
When I had a breakdown in Glochester and the British Olympic bronze medal winner Graham Brookhouse was at the bike shop we talked about this. Notice my name dropping there? He saw I was using g gatorsskin 28s and said they were more aero than 23s. He now focuses on iron man tri races and he said even a few watts saved makes a big difference over 112 miles.
bridgy
Cheddar
Hmmm I'd be interested to read any links you guys have to any articles on this?
I feel we might be confusing faster with more aero. Not necessarily the same thing.
Everything I've read says wider tyres - when optimised for aerodynamics by fitting to a wider rim - can be faster due to the better rolling resistance. But if you had narrower tyres that were also on optimal rims for aerodynamics, they would still be more aero (but not necessarily faster).
I'm no expert at all though and interested to learn more...
C
CXRAndy
Lincs
In ideal road conditions or laboratory testing, high pressure, narrow tyres are the fastest. In real world, crappy roads wider tyre optimised to the rim are proven to be a little more aero
Also the pneumatic benefits for a more comfy ride, allows rider to sustain higher effort, not worn down with vibration
View: https://youtu.be/yrHxQg1OW0A
JuhaL
Not an expert either but wheels profile effect also and rolling mass. Light weight is better and faster if we talk about tyres. Narrow tyre could be more aero but something tells me that rolling resistance matters more than tyres aerodynamic qualities.
bridgy
Cheddar
But Andy that video makes exactly the point I've been making!
Narrower tyres are more aero - he specifically makes that point in the video - even though wider tyres can be faster due to rolling resistance in real world conditions. When people say wide tyres on wide rims are more aero they mean more aero than wide tyres on narrow rims, not more aero than narrow tyres on optimal narrow rims. But even if they are more aero they may not be faster which is what I have been saying
bridgy
Cheddar
Yes agreed. All I said was wider aren't more aero than narrow (all things being equal). But despite this, yes they can be faster
bobinski
Tulse Hill
Aero? Isn’t the key to optimise yourself first? Get a bike fit, get flexible enough to go lowish, clothing,helmet, perhaps some narrower bars THEN look at wheels, tyres etcIts all cheaper and easier to get big gains before delving into the murky world of manufacturers claims. There was a good gnc vid about this a few years ago. Once you have optimised yourself then you might get another km an hour from decent aero wheel/tyre combo.
