star84
Regular
- southend,Essex
how and when should i grease my bike and with which product between which computer should i go for any recomendation ?
You can ride any bike in any weather. But if you get it wet or muddy you'll need to clean. You need to treat your bike like a lady: give her lots of tender loving care! Seriously, though, bikes are sensitive to the grit in the puddles and - at this time of the year - salt. It's not the frame - that can put up with a lot - it's the moving components, particularly the chain. The lubricant on the chain mixes with the dust to create a very effective grinding compound. So, by all means, ride now - but be prepared to clean it properly. One thing: don't lubricate your chain until you need to: it's already got a very effective lubricant and if you put too much oil on, all the s***e will stick to your chain. If your bike goes through dirt or gets wet, then you should wipe the chain and lube afterwards; otherwise, leave it alone.
Have fun!
How did the ride go? Glad you got the t3. What other bits did you get?
Your arse will take awhile to acclimatise, shorts will help. If it gets to bad just tape a large cushion to your saddle!
GJ on the ride.![]()
even with the tight or should i get a padded short plus the padded tight or something...
thanks anyway...
