What's the point of having lots of gears? (21, 24, 27, etc)
Thursday guy
Thursday guy
No - that is not correct.
Better to think of having a number of ranges with multiple chainrings rather than expecting them to be linear.
I don't understand why wouldn't be linear if you increase/decrease your speed?
I was under the impression that if you increase your speed while at chainwheel 1 sprockets 7, the next higher gear would be chainwheel 2 sprockets 1
If you read people's replies, then you would know that this was answered a fair number of posts back. ;)
Someone did try to explain it near the beginning, but I didn't understand it, hence why I'm asking again.
T.M.H.N.E.T
Northern Ireland
I was doing some test rides the other day. It was just along some quiet residential roads, mostly flat, with a fairly steep hill on one end (abut 7 degrees). Maybe I wasn't setting the gears up properly on either of the bikes, but I did try to make sure that I selected the one which allowed me to pedal at a 'comfortable' rate, and I was able to do so on the 21 gear bikes and the 8 gear bike, on the flats and uphill as well.
I do get what some people have said here, about the difference between each gear being smaller with a 21+ gear bike, so there should be fewer 'goldilocks' moments where you find yourself unable to sustain a comfortable pedal rate on any of the available gears. But I didn't have this problem when I was test riding the bikes, at least I didn't notice it.
Your test ride area isn't really the best for testing gear ranges is it? I'm sure I could maintain the same speed on the same bit of road on any of my bikes, but inevitably in NI at some point there will be climbing so what's the best option?
More gear ranges available :smile:
screenman
If you look at a gear chart like I tried to explain earlier, you will be able to work out how the combinations work. Or you could just experiment by pedalling and trying different combinations.
T.M.H.N.E.T
Northern Ireland
Why would you shift through the entire cassette? There's absolutely no reason to do so.
Try. You're too busy with numbers and not looking at numbers of gears and not how they would be utilised.
Thursday guy
Thursday guy
Probably not, but it was pretty much the typical commuter terrain - mostly flats, with some steepish hills. I'm not looking for a bike to compete in the tour de france.
SpokeyDokey
That was a silly reply.
You've had a lot of advice on the thread so maybe now is the time to accept/reject it and go and make your purchasing decision.
bpsmith
That would have been me, but you never said that you didn't understand.
Its all about the gear ratios. My Winter bike setup has 34-50 chainring (front) and 11-12-13-14-15-17-19-21-24-28 cassette (back). The ratios for my specific bike are therefore as follows:
34:11 - 3.09
34:12 - 2.83
34:13 - 2.62
34:14 - 2.43
34:15 - 2.27
34:17 - 2.00
34:19 - 1.79
34:21 - 1.62
34:24 - 1.42
34:28 - 1.21
50:11 - 4.55
50:12 - 4.17
50:13 - 3.85
50:14 - 3.57
50:15 - 3.33
50:17 - 2.94
50:19 - 2.63
50:21 - 2.38
50:24 - 2.08
50:28 - 1.79
So if I went from smallest gear 34:28, I would only need to go up 3 more gears to get to a ratio of 1.79, which is the same ratio as if I changed up on the front chainring and dropped to the smallest gear on the cassette. Do you follow?
Edit: hope so, as took ages to type on my iPhone!
Pontefract
@bpsmith or you could do this, in inches, assuning 700x25c
mine
%is the change between rear gears, the lower the number the closer the gears.
Thursday guy
Thursday guy
34:11 - 3.09
34:12 - 2.83
34:13 - 2.62
34:14 - 2.43
34:15 - 2.27
34:17 - 2.00
34:19 - 1.79
34:21 - 1.62
34:24 - 1.42
34:28 - 1.21
50:11 - 4.55
50:12 - 4.17
50:13 - 3.85
50:14 - 3.57
50:15 - 3.33
50:17 - 2.94
50:19 - 2.63
50:21 - 2.38
50:24 - 2.08
50:28 - 1.79
That's brilliant, thanks. I understand now.
by the way, the numbers for the chainring and the cassette are the number of teeths?
bpsmith
Indeed @Nigelnaturist. I kind of prefer using ratios tbh. Don't know why? Gear inches is probably better, but doesn't come as natural as ratio to me. Cheers for doing it though. :smile:
