I shouldn't worry about it! I don't have a clue about 'cadence', 'gear ratios' or any of that stuff! I get on my bike and if it's too hard, I change down a gear, too easy, I change up a gear. I don't eat the right stuff, drink the right stuff, wear the right stuff...and I certainly don't do
'Strava' or any of that bullshit...but I do ride one hell of a lot of miles and I really enjoy it!!
I do that B.S., though in all honest I am less keen on these days, I do keep meticulous records of my rides in my own database, but it only takes 5 mins or so, I just ride these days, 6-8,000 miles a year.
@Andy_R done that the having to cycle down hill bit.
Some riders are easily seduced by the 'more gears, the more impressive the bike'. I don't buy into this idea although it appears to be the way some manufacturers are going. If you are using the bike in question for local riding, then you need a range, range not number, of gears to suit. If you're likely to travel and use said bike in different areas, e.g., Bath or the Peak District are very different to York or Cambridgeshire, then you'll need a wider range of gears. A lot also depends on the bike and its setup; light frame & fast tyres will obviously need fewer gears than mountain bike with 1.5" nobbies. And just to muddy the waters even further, there are some who prefer to push big ratios and others who prefer spinning smaller ratios. It's a very personal thing.
Its not a matter of the more gears the more impressive the bike, I ride a Viking that I have upgraded from 21 to 30 (being a triple) like
@ColinJ much prefer them to doubles. I can gear it to cover a good range with a very
close group of ratios, this is what more gears is about not range, I could gear a 3x7 with the same range as 3x10 (triple and rear gears) but because of the extra 3 gears I can go 12-13-14-15-16-17-19-21-23-25 instead of 12-14-16-18-20-23-25 for example both would have the same range but the extra gears help no so much in climbing as you have the same range but in the abilities to spin in whatever the conditions are, if you have never ridden a close grouped cassette I suggest you do as you wouldn't want to ride a compact double again.
As for manufactures introducing more gears the opposite is true, there a fewer triple on the market than there used to be as Shimano have dropped the triple option on all but the lower to mid range, my 105 is 3x10 the new is 2x11 with no triple option as yet.
