You must be some sort of pro. What kind of riding are you doing?Trust me, there's not prejudice from me. As a beginner, I'm just confused by the need for so many gears, because I've ridden on both 21 gear and 8 gear bikes on flat and uphlll terrain, and I genuinely can't notice the advantages that the 21 gear bike has over the 8 gear bike.
as @Tigerbiten says the more gears (primarily on the rear) it gives you better options, take this example I had a 13/15/17/19/21/23/26 7sp when I started, I am looking at either a 12-13-14-15-16-17-19-21-23-25 or a 12-23, if you have ever ridden into a headwind where one gear is too high and the other too low, this is where the closer grouping comes in really handy, the triple on the front gives a really useful range, as for there being redundancy it cobblers as the duplicate gears would be used when in the right range without the need to change front and rear, when I shift from front inner to middle I have to change down (up the cassette) about 3 gears to be in the same range, the shifters will do 2 in one sweep of the lever, (you get adapt at it) its a little close on the middle to outer (less ratio difference between them) usually 2.Trust me, there's not prejudice from me. As a beginner, I'm just confused by the need for so many gears, because I've ridden on both 21 gear and 8 gear bikes on flat and uphlll terrain, and I genuinely can't notice the advantages that the 21 gear bike has over the 8 gear bike.
For a given road speed say 20mph you would need a 67.2" gear spinning at 100rpm, same speed at 80rpm you would need an 84" gear (assuming a standard road bike and 25c tyres), neither of which i can really do.
As you get more experience you will find it's more efficient to spin your legs at one speed.
It's normally somewhere around 70-90 RPM range.
By having more gears close together, it's easier to keep your legs at your preferred cadence, which will mean you can go further for the same effort.
Which is what I was getting at in my original post that you quoted.
You can move the same distance by either spinning or grinding (and all points in between).
ok fair enough, but what about the problem I mentioned in the first post where if you shift up a chainring (front deraileur), is it correct that you would have to move the sprockets shifter (back deraileur) all the way back to 1?
But not by keeping the engine running at it's most efficient revs.
Only if to keep the same speed and cad if its the same gear ratio/inch, it is feasible to change the front and be in the right gear on the rear, though it practise this doesn't happen often, if the front rings are closer say 30/38 instead of 26/38 it would be more likely.ok fair enough, but what about the problem I mentioned in the first post where if you shift up a chainring (front deraileur), is it correct that you would have to move the sprockets shifter (back deraileur) all the way back to 1?
For sure - although some people like to spin and others like to grind away irrespective of whether they are optimally efficient.
I can do both, I can spin and maintain 90 on this 1 1/2 mile 150ft climb, though only on a good day, or get out of the saddle and use a higher gear, all depends on mood ect......But few of those like to do both.
If you read people's replies, then you would know that this was answered a fair number of posts back.ok fair enough, but what about the problem I mentioned in the first post where if you shift up a chainring (front deraileur), is it correct that you would have to move the sprockets shifter (back deraileur) all the way back to 1?
He's taken a position and is sticking to itIf you read people's replies, then you would know that this was answered a fair number of posts back.![]()
