The Vanquish? I solved it by pushing the caliper as far out as possible and then running the outboard rotor piston all the way in (like worn pads) as I noticed that when braking only one piston moved with the 550’s but you could adjust on both sides! I threw the 510’s away as they are useless!Took another crack at the front disc brake and got it working nicely for all of 3 brake tests and then its back to square one .
Doing my head in now![]()
Yes, should of said I used to have to tug the spoke as I tightened the quick release to align the disc.The 550 you can adjust both but even fully out there isn't much play ,maybe half a turn of the adjuster . something to do with the qr and forks methinks as he back one is set up nicely.had issues with the 510 as well but not this bad ! If I set it up so it won't rub I may as well not bother having the brake attached.
Could the disc be out of true? I had a similar problem, and got a tool and trued the disc, no more rubbing since. I guess you don't really need a special tool, probably a large adjustable spanner would do.
nope , new disc
