What Have You Fettled Today?
richardfm
Cardiff
Yeahbut, I already think that I am an obsessive, boring b*st*rd even without someone hinting at it! :laugh:
2 potential problems...?
  1. If one is dual-pivot and the other isn't, you will now have the weaker brake at the front and the stronger one at the back, which is not ideal.
  2. If your brakes have slide-in brake blocks then they will now be able to self-eject under braking , which is DEFINITELY not ideal!!! :eek:
When @Jameshow said
Left is back, right is front
I assumed he meant the levers are the other way around compared to the convention in the UK, not that the brakes are the wrong way around. If this is the case then it doesn't matter.
Jameshow
The calipers are fine, I've just cabled them up back to front aka continental style. Both dp.
T4tomo
I answered a call of mercy over the weekend after my mate had booked his and his other half bikes bikes in for rather expensive "services" due to a couple of issues, and then had buyers remorse and wondered if I could take a look instead. We're doing a 4 day Newc to Edingburgh over the 2nd may bank hols.
First up his bike, as only getting largest 4 or 5 of the 8 sprockets as and when selected, although occasionally dropping onto them a mile or two after selecting them. Initial phone diagnosis was correct, a pretty rusty run of outer cable immediately before the rear mech, so replace that and re indexed the gears and running fine - told him he could do better at chain cleaning though!
Next up hers, "gear a bit noisy in the middle range" and "brakes not great". as I wheeled it to the stand you could tell something was up as it didn't wheel very freely, and a very short test ride was like pedalling through treacle. I dropped the front wheel out and it spun fine on it axel, so wasn't a bearing issue, but it was at both front and rear a cable disk brake adjustment issue. BB5s both rubbing against the passive pad but the active piston needing most of the lever travel to engage.
Needed the full loosen off, business card, squeeze and retighten caliper routine and then some dialling in of passive pads and inline adjuster adjustment. I then set to indexing the gears but that was proving futile as what worked at one end of the cassette range didn't at the other. Bent mech hanger diagnosed, and when i got the hanger toll out it was at least an inch out of line at the rim. Gently worked that back inline and indexed the gears. Quick test ride was like night and day. My mate said he wondered why she was lagging behind so quickly the other day, the poor lady had done 20 miles with her brakes partly on!
Not a bad hour and a 1/4s work.
T4tomo
I don't think it is possible to install the calipers that way, is it?
not the caliper, but you can orientate the brake pad carrier block backwards quite easily if you ignore the arrow showing the direction it should be in, and then your reliant on the little holder screw if it has one.
  • Like
Reactions: C R
ColinJ
Puzzle game procrastinator!
Ah! In that case, a problem might arise if you forgot at a time when heavy braking was required? You could end up locking the back wheel and putting the bike into a fishtailing skid?
DCLane
The Viner Mitus I'm putting together as a 'new' winter bike has had some touch-up paint, together with an Ultegra crankset taken off my Dawes Giro. Photos once the build gets started proper with Shimano 105 shifters / derailleurs plus other parts, unless I pick up something better in-between.
Also, I've cleaned my Ridgeback Platinum and swapped the Shimano 105 crankset for a Dura-Ace one. As the cranks are different length (172.5 old vs. 170 new) I'll probably need some adjustments. Or find a 172.5mm one off either the NeilPryde Nazaré or Thompson Capella. Doing the swap saves only 150g but it all adds up; a different crankset, new Velo Orange brakes, different wheels and lighter bottle cages have saved about 600g since I rode London-Edinburgh-London on it in 2017. Over 1200km on a heavy hector of a touring bike that matters!
The Dawes Giro 400 bike I was using on Zwift has had the CeramicSpeed bottom bracket removed; that'll be kept for my Raleigh SP Race as the Raleigh is now on the smart turbo instead. Over the next few days the Dawes will be stripped down and re-sold, with the rest of the groupset going onto the Viner. No rush, but I'd like to get it finished before the summer.
Finally, with a lot of help from the university shared workshop I have access to in Leeds, the recalcitrant / massively stuck bottom bracket on the Peugeot Optimum is now out and the frame re-threaded. That'll get a replacement square taper bottom bracket rather than the old cage-style one, with a different crankset, over the next week or so. After which it'll probably stay as a vintage / bad weather roadie until I can find something really nice.
Ming the Merciless
There is no mercy
Inside my skull
Building up a new front 406 tubeless dynamo wheel for the recumbent. Just done the lacing this afternoon. I find doing in stages, then putting away for at least a day stops frustration or shortcuts entering the build process. I’ll start bringing the spokes up to tension tomorrow.
I might get a matching rear rim to build up, and then make the current wheels my winter set.
palinurus
Velo, boulot, dodo
Watford
Did a quick repair this lunchtime with electrical tape and some plastic foam stuff I found. Added a label because I can never figure out which side is the on/off button.
Did start polishing the lens but will need to take more time over it and use some coarser diamond paste to start with- didn't make much impression on the bigger scratches.
This repair held up until I retired my Fly6 (today- due to battery life becoming very short).
palinurus
Velo, boulot, dodo
Watford
Washer dryer was leaking everywhere. Found a chunk missing from the door seal. Right- call engineer to replace. But no! I decided I would get some polyurethane sealant and fix it with that- but then I thought of something more immediate.
Cut up a cat food pouch and wedged it between the damaged part of the seal and the door. Perfect.
sevenfourate
Devotee of OCD
What flavour was it ? In jelly or Gravy ?
