DCBassman
- The lumpy far South West
Desktop computers. Very slowly and carefully, still not very bendy...
Wanted to change my Gatorskin Hardshells off the Orbea today but just couldn’t get the bead to budge off the rim for the life of me. Was actually concerned that I might damage my wheel I was having to put so much force into it.
Ended up sacking it as the hands were getting raw. Tool ordered for tomorrow. Glad I never had to do this at the side of the road, would definitely have been stranded.
Yeah tried that but just dug into the tyre unfortunately. I have one side off but the other side is welded on. Didn’t even get to the rear tyreI've used pliers in the past to work a reluctant tyre of the rim.
Hopefully the fettling required on my TT bike is minimal the rear drop outs are worn. The local bike mechanic refaced them a few years back and with a more sturdy skewer its not been too bad. But when I started yesterday's TT I managed to pull the wheel out of alignment so it was rubbing the frame. Riding 10miles on it hard wasn't the best idea. Hopefully resetting the QR will resolve it for now or it will be another trip to a bike shop.
View: https://youtube.com/shorts/XuK062JiQsA?feature=share
Something has also been making a clack on the turbo when it's giving resistance, although it has been silent in the stand. I think when I was testing the wheel I found out what it was.
Its cracked inside, a multi tool fettle tightened it up snugly for now. If the bike on the turbore is still making a noise it'll be coming off.
My other post ride fettle was my right pedal. Something was also making an annoying creak and I suspected it was the pedals so I lubed their springs last week but the noise was still there and seemed to be animating from the right side, so I took off the right pedal cleaned the spindle, washer and eye before regreasing and refitting. Hopefully that solves it as I don't really want to take off the left power pedal (it's the older type and there's always a doubt over its numbers when you change things).
Pleased the tyres went on without trauma! You may notice they lose some pressure overnight, especially when new. Mine go from 60 to 50 psi after a couple of days then the rate of loss reduces. Experience suggests they lose less as they spend longer on the rim although I pump up before most rides.After 7 punctures ( 3 different bikes) already this year, I've made the switch to tubeless on my most used bike, the Ribble. Fitted Schwalbe One 28mms onto Mavic Krysium UST rims, all went surprisingly easily. Tyres went on without a fight and without levers, pumped up with a track pump ok and held air for an hour without any sealant. Orange regular sealant now added, the acid test will if they still hold pressure overnight ok, all indications are that they will be fine. No intentions as yet to switch my other bikes over to tubeless as there's a small pile of spare tyres in the garage that need using up!
