I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
I have had a busy day in the sun giving the hybrid a good seeing to!
Finished tensioning the new wheels then fitted them so swapped rim tape, tyres, brake discs and cassette. New wheels are a whopping 77grams lighter. I also took the opportunity to strip and clean the cassette as it was packed solid between the smaller sprockets.
Cleaned the chainset as that was similarly gunked up between the chainrings.
Stripped and cleaned the rearmech, the jockey wheel bushes were bone dry
Pulled out the rear gear cable inner from it's full length outer and cleaned/oiled that then reset indexing and stop screws. Gears now move perfectly.
Fitted new chain.
Cleaned and greased headset bearings.
Reset hydraulic caliper adjustment as new hubs are fractionally different (we're talking maybe less than 0.5mm here!)
While The chain was off I noticed the bottom bracket sounded a bit rough (Hollowtech II SM-BB51) so that will need attention sooner rather than later.
Most of the above only happened because I was fitting new wheels, it's amazing how a job can snowball. The main aim of the new wheels is strength and reliability so the small weight saving is a bonus. This should be an end to my wheel woes.
A few small bits of tinkering still to do but that is the biggest part of the work out of the way. That's the most attention the bike has had in 2 winters and over 3000 miles.
Still to do-
Fitted new chain.
Still to do-
- Bottom bracket
- New chain is jumping slightly on old cassette so will see how it goes after 20-30 miles then consider a new cassette.
- Cable routing needs tidying a bit and possibly swap sides for front and rear mech cables at the top of the down tube.
