What Have You Fettled Today?
biggs682
Northamptonshire
Was it that clean when you got it out?
Considering it was late 80's bike it was in very good condition, should be fine once cleaned and re greased
DCLane
Piccies??
Progress photo to date. I'll need to remove the forks to have a better look at the headset, at which point the quill stem will drop down, then decal the lot. I've a set from H Lloyd of stick-on decals which are about as period-correct as I can find:
It's far too big for me, being of shorter stature, so what I'll do with it is unknown. However, it's been a learning process ...
cyberknight
Sold my Felt bike, just gave it a last adjustment and a clean before the off. Why do people turn up in rural area's with only their phone to pay ?
Several times of late as I have reduced my collection, they turn up and complain about the lack of signal. I even warned one chap and he assured me it would be okay. It wasn't and we spend ages hanging around outside as they try to connect.
I had the same last year selling a bike as they wanted to pay with some app I have never heard of and had to find an atm
Punkawallah
One Cresta ladies bike. The gear cables along the frame were not in cable housing, even though there were brazed on attachments the cables were not in cable housing, but the frame also didn't allow for cables to be fitted any other way; very odd.
I ended up putting the rear cable in a new outer cable. leaving the other alone and sending the bike out for 95€.
Guesstimated at 95 Euro, or is there a scale of charges for what is done to the bike?
A bit of both. We have a scale of charges based on the time spent, value, and new/used parts added, but a sub 100€ bike is outside of this; in theory, we are supposed to see if the brakes work and the gears work, pump the tyres up, and give it a polish. In practice this rather utopian ideal rarely happens; in this case I had to change an inner tube and rear gear cable and de-clog the shifters.
Normally I'd charge a bit more as it was a Nexave groupset and generally in good condition but with this odd cabling I decided to reduce it, so someone will get a very nice bike for pocket money.
Gillstay
Got given this today and looks like an easy job to make good.
I do them up then my brother takes them to a BMX club in a poor part of London to help youngsters get a better start in life.
sevenfourate
Devotee of OCD
Ably assisted by a 6 month old Cockerpoo tidying up the old bar-tape, unaided, I wrapped the bars anew.
With 12,000 miles on the original tape, it was looking a bit tatty.
New hoods, too, but they went straight in the recycling.
Unless I’m blind as the proverbial bat; you've kept him / her quiet ! Gorgeous looking pooch. And I can see the a spark of the devil in them eyes in the last pic.
Have fun together……..
ColinJ
Puzzle game procrastinator!
I had a quick look at a friend's bike yesterday. I don't think she has ridden it for about 5 years so it needed checking over before we go to Cumbria with our bikes next week***.
The front gear change was iffy so I sorted that out. Surprisingly, the rear shifting was spot on.
The front brake blocks are worn right down to the limit markers. I once made the mistake of trying to squeeze 'just one more ride' out of worn blocks and ended up trashing a wheel rim; I won't make that mistake again! I ordered new blocks which arrived today. I'll fit those before we go.
The chain should last the holiday but it is very dry so I will lube it and go for a quick test ride to check all is well.
The bike has new tyres which I fitted 5 years ago and they look like they have barely been ridden. Unsurprisingly, they were flat after years of non-use. I pumped them up and I just rang my pal to see if they had stayed inflated - they have.
I would have used the new ones and chucked the old ones away! :okay:
*** I promised that we will not tackle rides longer than 25-30 km and I will make sure we avoid horrendously hard climbs! We will share cooking duties during our break. If the weather is fine on the evenings when she is cooking I might nip out and get hill-and-distance-top-ups in then!
sevenfourate
Devotee of OCD
Brilliant. I’m into retro BMX’s. That means you end up having loads of spares kicking around of course. I’ve built up and given away two so far. One of the recipients I met myself. He had a grin like all his Christmas’s had come at once. Great to see 😎
PeteXXX
Photo Winner
Hamtun
Unless I’m blind as the proverbial bat; you've kept him / her quiet ! Gorgeous looking pooch. And I can the a spark of the devil in them eyes in the last pic.
It's our daughter & grandkids puppy. We're doggy-sitting the little bundle of mischief for the week while they're away camping..
sevenfourate
Devotee of OCD
Sounds fun. Have a great trip…..
ColinJ
Thanks.
The weather might be a bit iffy but as long as we can get out every day on the bikes or on foot without getting absolutely soaked we will be happy. We won't be going up onto the fells but we hope to get to Coniston and Windermere as well as round the north side of Morecambe Bay.
