A worm is a strip of rubber you insert into the hole with a fork like thing. The idea is that it takes some of the space up and the sealant does the rest. Unfortunately my limited experience is the worm makes a bid for freedom if the pressure is more than about 50 psi. The dynaplug looks a better design because of the arrow shape. I need something otherwise I’d be putting a tube in. Fortunately I am confident I can do this at the side of the road with my tyre and rim combo. I’d have no chance of reseating a tyre tubeless with a handpump.
I inserted the worm with the Muc Off tool, it looked to have worked but after leaving it overnight it seems to have worked its way back out the way ! Now resembles a goldfish doing a "number 2" !!![]()
I was probably a bit hasty. Had I not ordered another when I read a few more accounts I would have tried patching from the inside. I’m also interested in those dynaplugs that seem to be arrow shaped and should anchor better than a worm.So do you reckon I need a new tubeless tyre? I'm half tempted to return to my two tube tyres as they are just sitting there ready to use.....Hmmmm, what to do....
I've made another attempt at blocking it with another worm.
Then you have to fully clean and re-fill with sealant?patch the tyre from the inside with an inner tube patch, IMO which is limited those worms tools are crap they might get you home if you're lucky
My equally limited experience of worms (one use) is that they are ok but shove them in well and use the fattest you have. I had a skinny one blow out but the fat one held ok.patch the tyre from the inside with an inner tube patch, IMO which is limited those worms tools are crap they might get you home if you're lucky
I've no experience of worms but the description and described use makes it sound as if it's 50/50 on whether or not they work other than as a get you home.I was probably a bit hasty. Had I not ordered another when I read a few more accounts I would have tried patching from the inside. I’m also interested in those dynaplugs that seem to be arrow shaped and should anchor better than a worm.
Love that.I've always thought Dynaplug as a breed of worm if you see what I mean.
Yes, I see where you're coming from.@Dogtrousers you must be the only person here who dreams of having a puncture. 🤣🤣
